Crazy? tow question
varmint
First Name: Vernon
Last Name: Worley
Crazy? tow question
Post by varmint » Thu Nov 20, 2025 6:54 pm
When you are driving along at speed and then put the Model T in neutral, so that it's coasting...the engine is turning but the rear wheels still going at speed, and this does not hurt the car?
Can't we flat tow the Model T in neutral with the engine running?
Vern (Vieux Carre)
First Name: john
Last Name: karvaly
Re: Crazy? tow question
Post by speedytinc » Thu Nov 20, 2025 6:58 pm
Yes. & you can tow in gear with the spark plugs removed.
The point is the engine needs to keep moving/splashing oil into the bearings.
Post by TXGOAT2 » Thu Nov 20, 2025 7:18 pm
"Coasting" in "neutral" will do no harm, AS LONG AS THE ENGINE IS RUNNING. There's no point to it though, unless you want to go very fast down a very steep hill.... which is a very bad idea. The Model T does not have a ball bearing throw out bearing... just a little fork-like thing. I don't think it was designed to be held in "neutral" for extended periods with the engine running.
