Interesting modification on Fordor on MTFCF
Topic author - Posts: 1967
- Last Name: Tannehill
- Board Member Since: 2002
Saw this & it’s pretty neat looking modification.
A young Lady named Kathy Paschkov in Springfield, MO Is in need of some mechanical help if anyone can assist.
Best John
https://www.facebook.com/share/p/19GzrP ... tid=wwXIfr
Best John
Re: Interesting modification on Fordor on MTFCF
I'd want to put a late roadster/touring windshield on that, and add a second windshield at the front seat back with a removable soft top stretching from the remnant hard top to the second windshield. That would make a nice Town Car.
JohnM
- Last Name: Michaelree
- Board Member Since: 2010
That's a one of a kind custom town car!
Shouldn't have any trouble finding help with that. Springfield's Heart of the Ozarks chapter is very active.
John could you provide her a contact & contact information?
Best John
Best John
No contact info is given; you would need to go to Facebook and contact her through there.
TMiller6
- First Name: Thomas
- Last Name: Miller
This modification looks nice but it also scares me. The B-pillar with the strikers is also supporting the seat back This pillar is bolted to a wooden sill with 4 or 6 wood screws through an iron bracket on each side. With two people in the front seat, I’m guessing the rear doors will be hard to open and close since there is no longer two roof beams resisting the upper movement of the pillar.
Tom Miller
A brace across the seat back structure might be needed. Something like a second dashboard. The car would still lose some torsional stiffness, but as long as the doors stayed shut when driving, it wouldn't matter much. T touring cars and roadsters have very little torsional stiffness, and they do OK.
Hopefully someone will help this person out & perhaps answer the questions that are posted.
bnchief
- First Name: Steven
- Last Name: White
I have already reached out to her to see if i can help or get her to someone who can.
bnchief
- Last Name: White
- Last Name: Patrick
Granted, a lot of work went into this modification, but not enough thought. I would have preferred the roof be moved forward so as to cover the entire rear seat and rear floor section up to the back of the front seat, with a windshield separating the rear from the driver with just the driver and front seat exposed to the elements. The way it is now with the roof covering just the back seat, it does not provide enough protection for the rear seat passengers. The least bit of rain will soak their legs. Virtually every towncar I have ever seen has the driver and front seat uncovered with the rest of the interior protected from the elements.
It was used as a parade car and was made to the rear seat occupants could be seen and still had some protection from the Idaho sun.
"it was used in parade in Idaho with Governor Cecil Andrus in the 80’s"
