Rear brake shoes
bjesplin
First Name: Blair
Last Name: Esplin
* REQUIRED* Type and Year of Model Ts owned: 1909 Model T Touring
Rear brake shoes
Post by bjesplin » Mon Nov 24, 2025 11:07 pm
I discovered that the left rear brake on my car does not contact the drum. I adjusted the rod as far as I could to no avail. I took the wheel off to inspect the brake shoes. I couldn’t see anything wrong but I don’t know what I should expect. The shoes have no lining which I believe is normal. Does anyone have experience with lined shoes? Would a new set of standard unlined shoes solve the problem?
Re: Rear brake shoes
Post by Allan » Tue Nov 25, 2025 6:39 am
You may have a combination of worn shoes, worn cam and worn brake drum. New cams are available, new lined brake shoes are available, but I believe new drums are no longer available. You can fit a sleeve over the cam to help wear at that point. A worn one piece cast iron shoe is more likely to break if it has to be expanded into a worn drum. While you are at it, check fro loss of travel in the rods due to worn clevises and levers at the rear.
Post by DanTreace » Tue Nov 25, 2025 8:49 am
Could be the cam is so worn it cannot expand the shoe to grip inside the drum or the bushing of the cam is worn and won't let the cam fully lift. Replace cam bushing and the cam.
An old time fix is a sleeve to go over the cam. Have used these sleeves avail from Lang's and it works ok, needs a little grinding on the O.D. to get good fit.
IMG_7320 (481x500).jpg (134.39 KiB) Viewed 121 times
When testing, be sure the brake cam can lift the shoe, test by removing the clevis and pulling forward on the lever to check. Any wobble means worn bushing or cam. Pulling lever rearward will release the shoe as cam is now level or parallel with the axle shaft. The iron shoe could also be worn down and the drum may have worn more thin.
One fix is the new lined shoes.
Lined brake shoe.
IMG_0976 (600x450).jpg (112.18 KiB) Viewed 121 times
