What are size of the replacement driving plate rivets for a 26?
I have some on hand that “ I believe “ are the right size?
Truth be told I ordered some a couple of years back,
Used what I needed ,….. then lost the packaging !
Driving plate rivets dimensions?
jab35
- Last Name: Bartsch
Re: Driving plate rivets dimensions?
From Lang's
https://www.modeltford.com/item/3325RIVB.aspx o/s 0.265" Diam
https://www.modeltford.com/item/3325RIV.aspx std 0.250" Diam
Dave1
Topic author - Posts: 130
- Last Name: Eddie
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Thank you.
J and M Machine
- Last Name: Gulbankian
If the rivets are loose I would recommend you check the plate for cracks as they crack between rivets.
- Last Name: Hatch
Having found many, many driven plates cracked I have wondered if they could be repaired. Has anyone ever tried using the Loc n Stitch method to repair one?
How about welding? Or any other method? Dan
I have seen these drive plates with 3 1" welds between the shaft flange & plate.
I like the added rigidity. Those few cracks become irrelevant.
Used drive plates are still plentiful enough @ swap meets for $10.
