Ross steering box
WorldChamp1914
Topic author - Posts: 405
- First Name: Gary
- Last Name: Hagen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Ross steering box
Is Les Schubert still working on the reproduction Ross steering box?
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: Ross steering box
One has been installed in a car and it has been found to be very nice to drive. Unfortunately it only fits the 26-7 T.
As part of the installation it needs a frame rail “doubler” (about 2 ft long). A easy source can be cut from another 26-7 frame. The “drag link” needs to be either twisted standard T or I’ve used a pair of model T tie rod ends and custom made piece of tubing.
I apologize for not responding earlier to people about this earlier, but I’ve been distracted with other projects
Reno Speedster
- First Name: Morgan
- Last Name: Blanchard
Les,
Do you have any pictures? Is the plan to market them at some point?
Les Schubert
- First Name: Les
I am only doing the one production run so maybe 6 will be available
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Was there a Ross steering for pre- 26-27 cars?
- First Name: Keith
- Last Name: Townsend
At one time my wife's speedster HAD a Ross steering box. Unfortunately it was removed before I bought the car for her. The Ross steering box had been replaced with a Vega steering box. It works fine. But unfortunately is not an era correct steering assembly.
- First Name: Henry
- Last Name: Lee
Ross steering boxes can be found in various types that are easy to adapt, ie, early Jeeps, early Willys, Crosleys, Cushman, early golf carts of various manufacturers, even old tractors used them.
Just do a little research
Jamie Maxwell
- First Name: Jamie
- Last Name: Maxwell
- * REQUIRED* Type and Year of Model Ts owned: 1919 touring
Allis Chalmers B,C, and CA tractors used both Ross and Gemmer steering gears !
- First Name: Henry
- Last Name: Lee
If it does not turn in the direction you require, use a bell crank from a Jeep forward cab. Just follow the 90 degree rule of steering geometry in the push/pull at the attachment points. The internet has all of this.
