Rebabbit Block
Danny Carstensen
First Name: Danny
Last Name: Carstensen
* REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1922 Roadster
Board Member Since: 2014
Rebabbit Block
Post by Danny Carstensen » Mon Jul 01, 2019 8:03 pm
Looking to have my block babbit redone. My 22 has .016 end play & no shims left on the rods.Thinking of grinding the crank .010 under , pickup rods from a supplier. The block is std bore with no ring groove. Hone and ring the pistons. Not to many left doing the babbit thing.Can't seem to contact Andy Loso. Who else does babbit within a reasonable distance?
Dan (Southwest Minnesota)
Re: Rebabbit Block
Post by RajoRacer » Mon Jul 01, 2019 8:14 pm
Model T engine bores don't get a ring groove as the top compression rings goes to the top of the bore.
Joe Bell, Kevin Prus or Jack Putnam are close.
Danny Carstensen
First Name: Danny
Re: Rebabbit Block
Post by Danny Carstensen » Mon Jul 01, 2019 8:22 pm
Thanks Steve. Where are these men located?
Re: Rebabbit Block
Post by RajoRacer » Mon Jul 01, 2019 10:31 pm
I believe in Ohio.
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Re: Rebabbit Block
Post by Jack Putnam, in Ohio » Mon Jul 01, 2019 10:39 pm
I would be happy to Babbitt your block, I've 30 years experience, did the T-100 project for Ford Motor Company, work for the Henry Ford Museum and a few hundred other T engines using KRW equipment. I only do Model T engines, none other. I'm located in NW Ohio!
photos b4xp 048.jpg (25.76 KiB) Viewed 5625 times
photos b4xp 539.jpg (38.13 KiB) Viewed 5625 times
Sean Butler
First Name: Sean
Last Name: Butler
Re: Rebabbit Block
Post by Sean Butler » Tue Jul 02, 2019 6:28 pm
Lookin' good, Jack! Do you bore your own rods as well and if so, what sort of setup do you have?
Sean Butler
Huntington Beach, CA
Danny Carstensen
First Name: Danny
Re: Rebabbit Block
Post by Danny Carstensen » Tue Jul 02, 2019 7:43 pm
Thanks for all the information. Andy just called me, he's been pretty busy. Thanks again
First Name: Jack
Last Name: Putnam
Re: Rebabbit Block
Post by Jack Putnam, in Ohio » Tue Jul 02, 2019 8:57 pm
Sean: Yes I bore my own rods. They are set up on a milling machine, then bored to desired size.
Sean Butler
First Name: Sean
Last Name: Butler
Re: Rebabbit Block
Post by Sean Butler » Sun Jul 07, 2019 12:24 pm
A Like Arnold Small.jpg (11.13 KiB) Viewed 5196 times
Sean Butler
Joe Bell
First Name: Joe
Last Name: Bell
Re: Rebabbit Block
Post by Joe Bell » Sun Jul 07, 2019 3:32 pm
I deliver to hershey every year to East coast buys, Joe
