Are you in Winfield?
Topic author - Posts: 7410
Here I am in the old folks' home, without a T. I haven't hand-started an old car since September 7, 2023. I've been wondering if I'm now physically up to the task. Probably so, but it would be nice to give it a try and see if I can still crank-start. Does anybody on the forum have a running T near or in Winfield, KS, that I could try to start? If so, contact me through the forum, and we can pick a date and time of day.
- First Name: Henry
- Last Name: Lee
Re: Are you in Winfield?
Who is paying for rehab and your deductible if you hurt yourself? Asking for a friend.
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
That there is just pure love for the T...
I hope to keep cranking my '14 for years to come, but with the rebuild this year I'm adding a ringed flywheel and starter mag in case I ever need to swap out to a hogshead w/starter
varmint
- First Name: Vernon
- Last Name: Worley
Steve,
When my starter was out some time ago, you sent me a link of you hand cranking your Model T. I can still see it in my mind.
Thanks,
Vernon
Thanks,
Vernon
Vern (Vieux Carre)
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Aussie16
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
If I were closer, Id find a T,pick you up and do a road trip to the Old Car Festival with you! Hopefully someone can swing this for you? Good luck with your quest to crank a T again.
Virtus
- First Name: Paul
- Last Name: Robertson
- * REQUIRED* Type and Year of Model Ts owned: Ford model tt 1921 right hand drive
No takers for Steve's request! A chance to chat with one of the major contributors to these columns by giving him the chance to swing over a T one more time. Unfortunately I'm in the U.K. and unable to help. Good luck Steve and thank you for all the information and entertainment in your blog.
UPDATE: We've got it covered. I've received a call from a T owner who lives a couple of miles from me. We'll be getting together for a bit of starting practice.
Good news.... I hope you have fine weather.
- Last Name: Hjortnaes
I think someone should bring a T to the Winter Clinic and Steve starting it there will be one of the presentations.
Today was it. Steve Behrendt brought his 1925 and we found that I can still pull a crank and start a car.
Starting on BAT is still easy. I tried several pulls on MAG, and it was a no-go every time. I don't know if that was because of me, or a weak magneto. But the car ran on MAG with no trouble at all.
It was a bit of a surprise that with many years and thousands of miles of Model T driving, two years without any have made me a little rusty. I was able to drive a little, but I felt like a beginner.
ATTABOY!!!
Virtus
- First Name: Paul
Well done Steve!
South Park Zephyr
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
It is wonderful to see you behind the wheel again
Scott
Scott
My car starts easier on battery if it has sat overnight. For the rest of the day, it starts as easily on magneto. I'm not sure why since for most of the summer the car is already half warmed up from the ambient heat.
George Mills
- Last Name: Mills
Kudos Steve J. Thank you Steve B !!!!
- First Name: Austin
- Last Name: Farmer
Great to hear!
Congratulations!
Congratulations!
RGould1910
- Last Name: Gould
Way to go, Steve!!
Keep it up!
Keep it up!
Sean Butler
- First Name: Sean
- Last Name: Butler
Cody Winters
- Last Name: Winters
- Board Member Since: 2023
Fantastic to see you still have it!
keep up the good work Steve!
