I’m stumped
George Mills
Topic author - Posts: 645
- Last Name: Mills
I’m stumped
This is the first time the carb has been off in 30+ years.
It’s an NH
What ‘magic’ was it supposed to do ? ( the coil spring)
Thanks in advance….
It’s an NH
Thanks in advance….
John.Zibell
- Last Name: Zibell
Re: I’m stumped
Increase turbulence for supposedly better air/fuel mixing. My help, probably doesn't.
1926 Tudor
- Last Name: Hatch
Re: I’m stumped
Not an NH . Simmons or Wizard. That is a heater.
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
Re: I’m stumped
+1 on Dan,
Sure looks like a rudimentary pre-heat unit to me
George Mills
- Last Name: Mills
Re: I’m stumped
Thanks,
Son checked closer, found nameplate—-is a Wizard —-lol
Must have been a good carby…never an issue in my 29 years of stewardship! He just thought to rebuild it ‘just ‘cause’ as part of his stewardship.
Re: I’m stumped
My personal experience is, "just because" rebuilds are never worthwhile.George Mills wrote: ↑Sun Jan 11, 2026 6:20 pmThanks,
Re: I’m stumped
especially when the only part you can buy for that carb is the bowl gasket and a float valve (and you'll never find them by looking for "Wizard" parts) and neither were apparently faulty...but hey, his heart is in the right place and who doesn't want to help out his dad?My personal experience is, "just because" rebuilds are never worthwhile.
Re: I’m stumped
That is a heating coil to vaporize fuel. Battery power gets connected below that long knurled nut. Close to the carb bottom. There are insulators to route power thru the long screw, grounding the other end of the spring to the carb.
I have not seen any direction as to weather the power is on constantly while running or not. I suppose the power connection would be taken
from the ignition for starting on BAT then be off when the ignition switch diverted to run on MAG. Then the spring acts a turbulence device.
Re: I’m stumped
The springy thing is most likely an electric "fuelizer" or pre heater for cold weather starting. It appears to have a terminal on the bottom of the air horn. The driver would push a button or flip a switch to apply battery power to the resistive heating element. I don't think it is original to the carburetor. It may be in the 1927 Western Auto catalogue on the Cimorelli site.
Re: I’m stumped
I'd think you'd want it off once the engine started, and having it on for more than a second or two without cranking the engine might allow it to get hot enough to ignite any gasoline in the carb throat. Neat item, and useful if handled properly.
Re: I’m stumped
That heater is original on all the variations of that carb I have & have seen. Many have had the heating element removed & the hole plugged, but the hole remains. Wizzard, Simons super power, Duplex, Western auto?, maybe one or 2 other names for the same carb.
I am curious as to the carb's performance.
How do you or any other users feel it performs compared to a NH swayback or NH straight thru?
Re: I’m stumped
Definitely better than swayback NH and better than straight-through in that it takes very little choke or cranking to start. Like an L-4 (but without the L-4 poor fuel mileage) it uses a flapper to divert air through an idle bypass circuit until some speed/air volume overwhelms the flapper and negates the richness of the idle circuit at higher speeds.
Definitely worth the effort to locate one and use it if it's complete.
The NH float valve fits it, the NH float fits it, and a couple NH gaskets fit it, and that's it...all other parts are unique and though they look similar to NH parts they are not the same so you have to be very careful to be sure you're not buying something that is cobbled together with mis-matched parts.
Finally: DON'T LOSE THE THROTTLE AND CHOKE FLAP SCREWS. They are 4-36 (uncommon thread) round head machine screws and not an easy item to find or replicate
Re: I’m stumped
Can’t the Carb be taken apart if necessary to repair? From the picture it looks like the heater spring could be removed and be put back together. Is there an insulator gasket of some sort where the flapper shaft goes through the bottom? Others more knowledgable than me would know. If nothing was broken on it or leaking replace the gaskets and that’s it. Consider it a learning experience. Maybe clean out the small passages if any?
Re: I’m stumped
Thanks Scott for the performance review. Worth a try.
Re: I’m stumped
The flapper shaft is horizontal & parallel in front of the choke shaft. No gasket or insulator involved.John kuehn wrote: ↑Sun Jan 11, 2026 8:21 pmCan’t the Carb be taken apart if necessary to repair? From the picture it looks like the heater spring could be removed and be put back together. Is there an insulator gasket of some sort where the flapper shaft goes through the bottom? Others more knowledgable than me would know. If nothing was broken on it or leaking replace the gaskets and that’s it. Consider it a learning experience. Maybe clean out the small passages if any?
George Mills
- Last Name: Mills
Re: I’m stumped
How does it perform? As I said, in the almost 30 years that I drove the car there was ZERO issue with the carb. It however had a sweet spot for start, another sweet spot for run. That car is a stem winder and does start on mag. Set the sticks to cruise and in a roadster and the chase shadow car modern iron would say ya’ rounded out at 50…
Re: I’m stumped
The 1927 Western Auto Catalog describes a "Duplex" carburetor with an air valve and an electric heating element for cold starting. (Cimorelli Website)
"....... Duplex Improved Carburetor for Fords
The New, Simplified, Super-Power Carburetor, with built-in
heating unit, for Ford cars and Ford Trucks.........."
kelly mt
- Last Name: Kelly
Re: I’m stumped
I ran one, a Simmons, for about ten years. Car ran good.I replaced it with an OF and it runs a little better. I never hooked up the electric coil.
Harley_97
- First Name: Roger
- Last Name: Hallett
- * REQUIRED* Type and Year of Model Ts owned: 1924 Runabout, 1917 Runabout
Re: I’m stumped
My Carburetor has no markings as to whether it is a Simmons or wizard, but it definitely outperforms the sway back Holley NH.
It idles slower and runs smoother at all speeds. Mine doesn't have the preheat element. I think I would be leery of putting power to the heating element!
George Mills
- Last Name: Mills
Re: I’m stumped
Thanks all for the info and discussion.
It's my sons' stewardship now, as is my one of my other T's by the oldest son...let them enjoy ownership now-with me-rather than wait for the fateful day. My son had already bought and planned on installing a 'G' since the car is a '15. The rebuild idea was based on an unknown as in his life that carb has never been taken apart or even off of the car, but felt once cleaned and reassembled to be a back up carb in the trunk. He thought it was an NH and so did I because we never had view of the nameplate...lol. He's 3rd generation and been playing with this stuff since about 8 including driving and handling so some 35 years under his belt...and now a serious steward in his own right as he also keeps his late grandpa's Willys MB jeep honest and true under his stewardship.
Dunno yet but just may trade him that Wizard for a rebuilt NH of which I have several on the shelf all cleaned, and nice...lol
