Zoom Zoom
Zoom Zoom
Post by Dollisdad » Tue Jan 13, 2026 11:23 am
Re: Zoom Zoom
Post by Dollisdad » Tue Jan 13, 2026 11:24 am
Re: Zoom Zoom
Post by Dollisdad » Tue Jan 13, 2026 11:25 am
Re: Zoom Zoom
Post by Dollisdad » Tue Jan 13, 2026 11:33 am
hull 433
First Name: Stan
Last Name: Gadson
Re: Zoom Zoom
Post by hull 433 » Tue Jan 13, 2026 12:34 pm
Something’s off with the “Boeing” photo. Proportions are off, body details wrong and the bystanders have blurred faces. Looks like AI.
Re: Zoom Zoom
Post by TXGOAT2 » Tue Jan 13, 2026 1:12 pm
# 2 looks very strange.....
ewdysar
First Name: Eric
Last Name: D
Re: Zoom Zoom
Post by ewdysar » Tue Jan 13, 2026 1:56 pm
Something’s off with the “Boeing” photo. Proportions are off, body details wrong and the bystanders have blurred faces. It looks like AI.
I agree. Weird Ford logo on radiator, eleven spoke front wheel, strange looking cowl lamps, improved windshields, etc. etc. There are certainly more unexplained things in this "photo".
I hate that these things are out there and that virtually nobody outside our community could spot the errors. The historical record is changing as we watch. :x
Keep crankin',
Eric
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Zoom Zoom
Post by Rich P. Bingham » Tue Jan 13, 2026 3:50 pm
Something’s off with the “Boeing” photo . . .
I agree. The historical record is changing as we watch. :x
Look closely at #2 - I think it needs a lot of explanation.
The “Boeing” photo is most certainly an AI pastiche. :x
Get a horse !
Re: Zoom Zoom
Post by Allan » Tue Jan 13, 2026 4:01 pm
Rich, i did, and it does!
Joe Bell
First Name: Joe
Last Name: Bell
Re: Zoom Zoom
Post by Joe Bell » Tue Jan 13, 2026 4:15 pm
The second I bet was hard on the ears!
Daisy Mae
First Name: Kurt
Last Name: Andersson
Re: Zoom Zoom
Post by Daisy Mae » Tue Jan 13, 2026 4:27 pm
Blow it up and look at the faces.
Not to mention several people appear to be missing legs/feet, but that's OK, looks like I found one of the missing legs on this lady....
Re: Zoom Zoom
Post by John kuehn » Tue Jan 13, 2026 4:41 pm
When I looked at the Boeing photo I did notice it looked to clean. From the first look it does seem authentic and more than some of the other AI generated photos of old cars. But other than that it’s fairly authentic. Just don’t look to close!
Thanks again for posting the photos of the early speedsters as they were the hot rods in their day! Interesting to be sure!
Re: Zoom Zoom
Post by TXGOAT2 » Tue Jan 13, 2026 5:04 pm
It's a nightmare in close up.
Luxford
First Name: Peter
Last Name: Kable
* REQUIRED* Type and Year of Model Ts owned: 1911 Town Car 1913 Speedster 1915 kampcar
Re: Zoom Zoom
Post by Luxford » Tue Jan 13, 2026 5:22 pm
the give away is the large size it's over 2.0 mgs all the others are only Kbs in size. Ai can improve the clarity of old photo's especially old newspaper dot images, BUT often it alters features which it doesn't need to do such as making disk wheels into wire spoke/large hub ones.
Here is a before from a newspaper and after from ChatGPT
Luxford
First Name: Peter
Last Name: Kable
Re: Zoom Zoom
Post by Luxford » Tue Jan 13, 2026 6:17 pm
Here is the Gemini version of the same photo
Mark Nunn
Last Name: Nunn
Re: Zoom Zoom
Post by Mark Nunn » Tue Jan 13, 2026 7:45 pm
#2, the full elliptical springs has me baffled.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Zoom Zoom
Post by ThreePedalTapDancer » Tue Jan 13, 2026 8:15 pm
Might be a set of these.
Luxford
First Name: Peter
Last Name: Kable
Re: Zoom Zoom
Post by Luxford » Tue Jan 13, 2026 8:53 pm
The original photo is too poor to show exactly what the front axle is but a discription of the vehicle says it has a standard Ford front suspension so the Ai has decided it should have dumb irons and half elliptic springs. Definately not a Hyde Fulcrum set up. That change shows how inaccurate an enhanced version by Ai can be, especially when you see it made the wheels wood spoke instead of disc. Its good at color versions of B&W photo's but details of objects can get messed up real bad.
One photo of a test for water and mud splattering off wheels was determined by the Ai process as being a " test on a dry dusty road"
Another good use of Ai is it removes the over lay of print in seconds sellers of photographs put on to discourage copying them easily, where I always had to spend a lot of time wiping them away.
hull 433
First Name: Stan
Last Name: Gadson
Re: Zoom Zoom
Post by hull 433 » Tue Jan 13, 2026 10:36 pm
I think #2 is a modified Model S.
Robert Kiefaber
First Name: Bob
Last Name: Kiefaber
* REQUIRED* Type and Year of Model Ts owned: 1906 model F, 1907 model R, 1915 centerdoor sedan, 1921 centerdoor sedan
Re: Zoom Zoom
Post by Robert Kiefaber » Wed Jan 14, 2026 12:39 am
There that’s better
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Zoom Zoom
Post by ThreePedalTapDancer » Wed Jan 14, 2026 3:54 am
On further scrutiny, you might be right. Certainly has some aspects of an S. Interesting, I don’t think I’ve seen a photo of an S cut down into a speedster, and the starter crank is in an interesting spot.
Re: Zoom Zoom
Post by Jerry VanOoteghem » Wed Jan 14, 2026 6:31 am
Yes. An NRS chassis but with a modified Model T radiator and hood.
Re: Zoom Zoom
Post by Allan » Wed Jan 14, 2026 6:44 am
It looks like Ai can't handle windscreens with straight bottom edges, and cowls that match. The Duncan and Fraser built 1925 bodies on Australian cars had this feature. These bodies were built under contract to Ford because the Ford factory in Geelong was not completed until the 1916 models came along.
Re: Zoom Zoom
Post by TXGOAT2 » Wed Jan 14, 2026 10:40 am
People who use AI to modify or enhance historic photos ought to put in some sort of plain language statement or marker to the effect that the image has been modified. Enhancing the old newspaper halftone images is a good thing, if done honestly. I don't mind colorized B&W images if they are labeled as such.
Re: Zoom Zoom
Post by TXGOAT2 » Wed Jan 14, 2026 10:41 am
Altering History can be dangerous. It's never a good idea.
Re: Zoom Zoom
Post by TXGOAT2 » Wed Jan 14, 2026 10:45 am
The Hyde outfit probably cost as much as a new Ford, and it apparently lacked any kind of damping, other than interleaf friction. Springs alone, no matter how elaborate, can't give good ride and handling on bad roads at anything much over walking speed.
Luxford
First Name: Peter
Last Name: Kable
Re: Zoom Zoom
Post by Luxford » Wed Jan 14, 2026 7:42 pm
A couple of Hyde Springs are on surviving cars, A friend had a NOS set in his accessory colection it was a well made system. It would be interesting to actually see what if any faults or advantages they have.
Often now, assumptions are made about the working of unusual old objects/technologies and the decision is more than not completely wrong. I would not have thought anyone would go to all the trouble to patent and produce and advertise their product unless when presented to purchasers it did basically appear to do what was claimed of it. From its ads it appears to be aimed at city dwellers using paved roads.
here is another ad from 1923.
Re: Zoom Zoom
Post by TXGOAT2 » Wed Jan 14, 2026 8:11 pm
Springs need damping when used on vehicles that move over irregular surfaces at any significant rate of speed, or that stop, start, or change direction rapidly. Leaf springs have some inherent damping ability due to friction between the leaves. Of course, if there is much friction between the leaves, the springs become stiffer. Various damping or snubbing devices, aka shock absorbers, for automobiles came on the scene early in automobile development. Hydraulic snubbbers/shocks /dampers, like pneumatic tires, were a great leap forward in automotive safety and ride comfort, and allowed for substantially higher road speeds than before.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Zoom Zoom
Post by Rich P. Bingham » Thu Jan 15, 2026 11:08 am
#6 is interesting, obviously a well-used T, the photo is from 1914 according to the license plate. Interesting windshield arrangement, and period documentation of “boxed” stripes on the hood ! What year is the car ?
Get a horse !
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Zoom Zoom
Post by Rich P. Bingham » Thu Jan 15, 2026 11:15 am
#7 a newish 1913 ? Difficult to see the distinguishing square doors, but the windshield and front fenders are ‘13 earmarks, right ?
#8 appears to be an ‘09 - license plate tells us the photo was taken in 1912. A “tourabout” sans windshield or top. Was it bought that way ?
Get a horse !
