Vertical front axle 1909
Last Name: Hjortnaes
Post by DHort » Mon Jan 19, 2026 1:20 am
I have here pictures from left and right of a 1909 front axle. As you can see there is no caster to the
front axle. I have a friend who also has this problem on his 1912 Model T.
Is this common on the earlier cars? Is it due to the wishbone being bent or on the upper side?
Should I just find a way to bend it and add a second wishbone?
Do I need new perches?
Thank you.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Re: Vertical front axle 1909
Post by ABoer » Mon Jan 19, 2026 3:46 am
Dave , turn your axel around .\
Toon
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Mon Jan 19, 2026 6:05 am
Dave,
I think Toon is right.
The Spring ax and the wishbone ax are even.
The angle to the front is on the lower side of perch.
I think you perch on the left side should be on the right and your right perch should be on the left.
Andre
Belgium
Eric Sole
First Name: Eric
Last Name: Sole
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster
Post by Eric Sole » Mon Jan 19, 2026 6:09 am
Dave, the first picture looks like there is some positive caster, just not very much. This would require twisting the axle (top of axle rearward) to bend the wishbone to the Ford spec of 5.5 degrees.
Post by Jerry VanOoteghem » Mon Jan 19, 2026 6:28 am
Am I correct that the early axles, with the shallow yokes, have a notch to clear the spindle arms? I know the NRS axles are like that. If so, it's clear what is the front side of the axle and it is not possible to "turn the axle around" as those clearance notches would be mislocated. Again, I'm going from NRS experience.
Post by Wayne Sheldon » Mon Jan 19, 2026 7:37 am
It may be that the wishbone is upside down? I have seen this a few times on brass era Ts, There may be a bit of angle built in, a slight tweak up where the front pin fits into the perch. Other than that, the early wishbone has no obvious up or down. I have seen several cases where flipping the wishbone over fixed the problem.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Jan 19, 2026 8:26 am
Definitely the perches are 180 degrees out. Just Sayin as Toon stated.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Mon Jan 19, 2026 8:44 am
There is some sort of issue with the geometry of the front end of that car.
It is supposed to be a straight line from the frame, through the spring, through the perches, and through the axle.
That car has a very jagged line and this will produce a binding suspension and a bad handling car, possibly the death wobble.
I suspect the spring perches are backwards but can not tell for sure.
That needs to be fixed first and the geometry needs to be rechecked again.
Other things of note:
As the wishbone ball and seat wears it moves up and reduces caster.
If it is too worn it will not help this.
Looking @ the pictures there might be caster in the car, or maybe my eyes are fooling me.
Check the caster @ the kingpin, that is the only place that really matters.
Most axles are bent in some way unless they have been straightened somewhere in the recent past.
If the wishbone to perch nuts were left loose it will wear the back of the perch and wishbone ends.
If there is some wear here a small spacer can be installed to replace the metal.
Only do this last if all other things are correct and not first as a quick band-aid
A good quality in depth inspection (and look for cracks or other damage) is needed to find out exactly where the issue it.
Mike
Post by Scott_Conger » Mon Jan 19, 2026 10:03 am
My eyes are telling me that as sitting, the spring perches are both aimed "down" toward the front and if the wishbone was removed from the pan, the springs would unwind and the perches would allow the axle to cant backwards giving more or less correct caster. From the pictures I do not suspect they are in backwards.
A quick check would be to pull 1 nut off of the wishbone - if the machined face on the perch (under the nut) is flat, it's in correctly, if there is a big radius on the hole, it's in backwards as that radius is meant to snug up against a machined radius on the wishbone, at the root of the part that sticks through the perch. If perchance the wishbone and perch were in pristine shape, and the perches were in fact put in backwards, it would be impossible to draw the wishbone up tight to the perch and a small gap would exist where the wishbone radius crashed into the square perch ID.
I don't own a print on the early wishbones but folks who I respect all state that the wishbone is made straight and then bent after assembly to get the correct caster. I do know that every "used" early wishbone I've seen is in fact bent, and if that "as bent" wishbone is installed upside down, it would result in exactly what we're seeing on these pictures.
Michael Paul
First Name: Michael
Last Name: Paul
* REQUIRED* Type and Year of Model Ts owned: 1911 touring, 1909 touring
Post by Michael Paul » Mon Jan 19, 2026 10:24 am
I had the same problem on mine, flipping the wishbone over cured it.
Definitely worth a try.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Mon Jan 19, 2026 10:29 am
If you haven't already done so, the first thing to do is place a carpenter's square against the lower spindle bushings as described and shown in the service manual to verify if there is positive, zero or negative caster.
If there is zero or negative caster, then flip the wishbone over as others have described and that alone may cure the problem.
Post by TXGOAT2 » Mon Jan 19, 2026 10:47 am
Someone who is familiar with the early front suspension needs to take a look at that. Improper assembly, incorrect parts, loose, bent, or worn parts, damage to the frame, cross member or oil pan need to be ruled out or corrected. The condition of the front spring affects caster. Engine mounts need to be as-designed. The steering system and springs need to be properly lubricated to work as they are supposed to.
Daisy Mae
First Name: Kurt
Last Name: Andersson
Board Member Since: 2024
Post by Daisy Mae » Mon Jan 19, 2026 11:50 am
The perches are in correct position per my eye.
With the axle positioned vertically (and therefore the perch pins thru the axle being vertical), then the spring and wishbone mounts would be canted forward as is seen in the pic. With the spring & wishbone mounts horizontal, the perch axle pin and top axle mating face would be canted back to provide caster.
The perches, and axle, are oriented fine from what it appears.
I have never been able to find any early wishbone specs detailing whether the rods were straight, or if they had a bend, and if so, how much. Regardless, in my search for an early wishbone with a good ball, of the 4 I have in my hands, ALL have a very slight curve in the last 6 inches (age/wear?), some greater, some less, but all there, in addition to the pin being angled from the rod. I would therefore agree with others suggestions to try reversing your wishbone first before you do anything with the axle. Other things to check would be the condition of the ball (worn undersize), as well as if the ball socket is seriously/deeply worn and may require repair or shimmed, both of which would also force the axle out of alignment canting forward neutralizing caster.
His axle:
Reflecting the perch in current position:
Perches mounted as is, but properly canted back:
My axle for comparison (both his & my perches in correct position):
Post by John kuehn » Mon Jan 19, 2026 12:47 pm
It looks to me from the comparison pictures that the 09 axle perch has a slight back twist to it. It’s not much but it is turned to right just a bit to much. Look close and compare the last pics that were posted. It’s canted backward but it’s turned back.
Post by Allan » Mon Jan 19, 2026 7:13 pm
Caster is set by the spring perches, which are angled so that the top of the axle beam is canted to the rear. The caster is maintained by the radius rod. The threaded ends of the forgings at the spring end are set at an angle to the Y of the yoke. If you set those threaded ends on the level, the arms on the yoke will rise considerably.
The geometry can be stuffed up by fitting the perches at the wrong ends of the beam. On later axles without the relief in the end yoke, you simply have to turn the axle around. if the radius rod is fitted upside down, that too will upset the geometry, as will "straightening" the threaded ends of the radius rod.
Post by John kuehn » Mon Jan 19, 2026 7:42 pm
From the looks of the 09 it doesn’t look like it’s driven much and the car has nice paint. If there is really a concern about the way it drives and handles it may be be best to pull the front end assembly, using another 09 as a guide, maybe turn the axle around as suggested, check the wishbone and spring perches. Put it back together and drive it. If you’re careful you shouldn’t have to repaint any areas around the axle. Then again it all depends how much it’s driven.
Post by Allan » Tue Jan 20, 2026 6:21 am
If it is the correct axle beam for a 1909, with the relief notches in the spindle yokes, the axle should not be turned end for end. The perches may need swapping. There goes the nice paintwork, but it can always be remedied. To get things right sometimes means undoing previous work and re finishing once things are corrected.
Post by Wayne Sheldon » Tue Jan 20, 2026 7:28 am
I don't know, maybe it is just me? Maybe I am wrong? But when I look at the photo looking through the wheel spokes and look at the spring perch? It looks to me like it is the correct perch on the correct end/side of the axle.
The photos aren't giving us a really good view of things. It also appears to me that the axle may be twisted slightly. The photos do not line the ends up well enough to be sure about that, either way.
We really need more and better information to be sure of anything. Is it a real 1909/'10 axle? Does it have the notches for the spindle arms? Are the perches in the proper places or not?
From the little I can see of it here, it appears to be a very nice early T. I would hope it could be driven and seen out and about at least a fair amount.
Post by DHort » Tue Jan 20, 2026 11:37 am
Wayne
This axle is from car #22 that was at the Winter Clinic.... The axle angle is exactly the same as a 1912 we are working on. Unfortunately we have not other early car to compare it to. We have removed the axle and are going to remove the perches and try a different set of perches. We do not know if that will make a lot of difference, but it is the only way we will know. The '12 does drive a bit squirrelly and the axle is almost vertical when holding a square up to it. Next work day in a week.
Post by Jerry VanOoteghem » Tue Jan 20, 2026 11:51 am
Wayne
Dave,
Did you first try flipping the wishbone over, as others have recommended? It worked wonders on my friend's car.
Post by speedytinc » Tue Jan 20, 2026 12:06 pm
Wayne
Dave,
Taking apart & switching parts blindly??
Removing perches is more often a process that destroys them, not to mention the paint.
Careful inspection of all the parts & checking perch angles would be a wiser start.
I figure a '09 deserves to be handled with the utmost care & respect.
Post by Scott_Conger » Tue Jan 20, 2026 12:26 pm
Jerry VanOoteghem wrote: ↑Tue Jan 20, 2026 9:51 am
DHort wrote: ↑Tue Jan 20, 2026 9:37 am
Wayne
Dave,
yeah, when you can confirm correct perch installation by removing a single nut, everything else above is pretty much ridiculous.
after those perches are unnecessarily destroyed (for what????????) they will never be able to be replaced as they are unique even among typical over-the-axle perches as they are an entirely different forging than later early style perches.
If the only way to know if it's fixed is by replacing perches, then I'd suggest getting an opinion from a different mechanic, because good advice is apparently not enough. My goodness, this is an easily diagnosed and usually easily remedied fault on an early T.
Since I was recently and quite profanely admonished here, that I am a horrible person for stating what used to be completely obvious to competent mechanics in the past, let me proactively take this moment to publicly apologize to anyone whose sensibilities I've just dented. It will save me having to send yet another "apology email".
Last edited by Scott_Conger on Tue Jan 20, 2026 12:43 pm, edited 3 times in total.
Post by speedytinc » Tue Jan 20, 2026 12:31 pm
It's quite common for T's to hit stuff, pushing the wishbone mount back.
Is it possible & have you checked the Crank case wishbone mount location?
Check EVERY possible thing before acting.
Adding a second wishbone?? :o :o :o :o
The suggestion blows my mind for a '09.
You are caretakers of the holy grail of model T's
Post by Scott_Conger » Tue Jan 20, 2026 12:46 pm
John
it's not just an '09.
If I read it correctly, it's apparently Model T #22
And if that's true, then there is no hope for this hobby in the future.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Tue Jan 20, 2026 1:08 pm
This car was produced November of 1908. Is it even considered an 09? If it is not the Holy Grail, it is at least one of the wineglasses used by the 12! :D
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Tue Jan 20, 2026 1:20 pm
Experts on the first 2500 will be able to tell is how early in 1908 they began to be built. The model introduction was in October of 1908, Ford presented them as the new 1909 model cars.
Get a horse !
Post by speedytinc » Tue Jan 20, 2026 1:30 pm
I am no expert. What I see from very limited pictures is a wishbone pulling the axle out of spec.
I think disconnecting from the pan & a little moving may show the axle re-aligns itself.
Could a 09 wishbone be different from later? Could this one be a replacement, improperly installed or incorrectly restored?
I would be consulting an expert. Kim Dobbins, Pete Eastwood or another well regarded early T man.
It's a measure twice & cut once situation for such a precious model T.
Post by TRDxB2 » Tue Jan 20, 2026 1:52 pm
Can't one just ID if the two hole perches are on the correct side by removing the wishbone nuts and looking to see if the hole has a radius or is flat.
Simple check.
Also to check if the correct nut is used - may have been mistakenly used when perches on wrong side because of the radius.
perch orientation.png (353.5 KiB) Viewed 2329 times
p nut.png (94.13 KiB) Viewed 2329 times
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Tue Jan 20, 2026 2:12 pm
As usual here we go pulling everything apart with no real idea about what you’re doing. It’s obvious you don’t know what’s wrong so much more diagnosing is in order. To pull it apart blindly is a crime. “ it ran yesterday and won’t start today so I’m pulling the head”. Don’t be that guy.
1915ford
Last Name: Cameron
Post by 1915ford » Wed Jan 21, 2026 10:48 am
Just wanted to share my research on the early axle beam. The first drawing for T-202 states clearly: “same as N-202”. This refers to the later nrs axle beams with removable spring perches. The “clearance notch” was added a couple months into calendar year 1909 and was removed later the same year. (Per factory release records) However i have observed both an original 1910 car and a period photo that have the clearance notch facing forward. I presume these were examples of old stock being used up so turning the notch forward disabled it. The original car i saw had the original pinstriping still showing so it was not a case of the axle being removed and turned around after manufacture. The caster angle of 5.5 degrees is set by the spring perch as stated above. The factory clearance notch was ground in a wide sweeping arch. I have seen other clearance notches which appear to be a sharp and narrow groove. The second type might be non-factory modifications or supplier variants. I have driven cars with zero and negative caster and they are very unpredictable in steering. To do this job right the perches have to come out so guide pins can be placed in the perch holes and kingpin holes to check the beam for straightness. They often became bent in service.
Post by TXGOAT2 » Wed Jan 21, 2026 12:42 pm
A Model T with the steering system and chassis in good order will NOT wander all over the road like a cartoon car. It won't shimmy, either, if the wheels and tires are in balance and run true. There will be no "slack" or lost motion in the steering system. The car will handle easily and predictably at any reasonable speed on any good to fair road surface. At appropriate speeds, the car will handle poor roads well, too.
Post by Allan » Wed Jan 21, 2026 7:04 pm
It should not be beyond a reliable and competent T model owner to verify if the axle and perches are correctly assembled and fitted to the car in the correct manner. if that is found to be true, but the caster is still off, then the radius rod is at fault. If it is disconnected at the pan and lowered to allow the axle to be set at the correct caster, the degree of off set in the radius rod will be evident. Perhaps, as mentioned, it could be removed and refitted the other way round to check. If this improves the situation, but still does not result in the correct caster angle, the radius rod needs to be bent to fit. This is done in the car, with a long, strong lever similar to that used to align headlamp stalks. In this case, the tool is fitted to the axle adjacent to the perch and levered up. alternating from side to side until the correct caster is achieved.
As Pat said, correctly set, the car should not be squirrelly. Setting the caster angle a bit more than 5.5 degrees is better than a bit less. To much more will make steering in reverse more fraught.
Post by DHort » Wed Jan 21, 2026 8:12 pm
Remember the pictures above are from the '09.
We are working on a 12 that appears to have the same problem. I have now been told
that the axle on the 12 is a 26 axle. Experts more knowledgeable than me have determined this.
We found some perches at the swap meet in McPherson and will determine what we need to do
to correct the issue. The wishbone is not the same on both sides so we may replace that.
We will wait until the cold comes and goes. -16 degrees tomorrow night.
Post by Wayne Sheldon » Wed Jan 21, 2026 8:19 pm
I have never measured the exact angle of the axle on any of the speedsters I have had. However, I usually give them a bit more caster than spec. I find I like the handling better with an extra degree or two of caster. And with the speedster's higher speeds, I find that advantageous. I rarely have difficulty backing up. And only one time did I encounter problems due to too much caster.
One of my quick rush together speedsters to make it to a scheduled Endurance Run, I barely got the car together in time to make a late tech inspection and starting line. I fired the engine up literally hours before the line up, loaded onto the trailer and drove a bit short of two hundred miles to where the Run was to begin. We pulled in for the late tech inspection with less than two miles on the car. lined up, and headed to the starting line.
The car ran great, and drove just fine, under ten miles per hour. Anything over fifteen miles per hour, the only thing the car wanted to do was go straight ahead! I struggled with it, arm wrestled with it, and fought all the way through the two hundred miles. We had several annoying breakdowns due to the car not being properly readied and sorted at all before the Run. We got a well earned "Hard Luck, but Finishing the Run" trophy after delays due to the car not being ready enough. We, and a good friend that chose to follow us the latter half of the way were the last cars to complete the two hundred miles. And it was one of the most FUN Endurance Runs I ever went on!
The next weekend, I carefully heated and tweaked the wishbone to bring the lowered front axle up a bit straighter. Then I fixed a few of the issues we found while driving the unprepared car. It quickly became one of the best driving speedsters I ever had.
Just a bit of side-drift to illustrate how caster does affect handling.
