Can someone tell me what year this car is?
1923orange
Topic author - Posts: 70
- First Name: Thomas
- Last Name: Black
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring
Finally got another T model, I’m sure it’s a hodge podge of parts but curious what year this looks like to you? Block is a 1919 and I don’t believe that’s the case on the body. Thanks
- First Name: Keith
- Last Name: Townsend
Re: Can someone tell me what year this car is?
High radiator, high cowl, and slanted windshield indicates late 1923 for the 1924 production through 1925.
Chris Instness
- First Name: Christopher
- Last Name: Instness
- * REQUIRED* Type and Year of Model Ts owned: 1915 runabout, T speedster
1923. No radiator apron (although that may be because of the aftermarket radiator shell) and no brows on the front fenders and a slanted windshield.
Door hinges appear the same length. If so, That would be a 25 body. Fenders are earlier 19-23.
High shell on a low radiator. Mix of both early & late motor mount or an aftermarket spring stabilizer plate added.
Yea its a heinze.
Yea its a heinze.
Mike Silbert
- First Name: Mike
- Last Name: Silbert
High Radiator, Low Radiator, It's both!
A low radiator is tucked inside a high shell
Run it the way it is and if anything needs fixing make it more correct if you want.
Looks like a great car to enjoy and not have to worry about.
The perfect example of how interchangeable Model T parts are.
I have worked on, driven (but not owned) a more mixed up Model T than that one.
Mike
Mike
1923orange
- Last Name: Black
Thanks all, door hinges are the same length so I would assume the body is a 1925?
Body looks good. A 25 is a fine T. 1 man top well secured to the W/S stands.
Get the correct high radiator & you'll have a very presentable T.
The incorrect earlier fenders & lower radiator apron isn't a hugely noticeable defect to all but us experts.
I see many T's with incorrect fenders, even a few with a mix of an early & a late.
Looks like a fine purchase.
1923orange
- Last Name: Black
Thank you all, it’s been sitting and has some rust but I’m excited to be back into the model T game again. Will go nicely with my 30 sedan.
1923orange
- Last Name: Black
Just to confirm it is a high or low cowl car?
The dogleg at the back end of the hood shelf indicates that it is a high cowl body. There is no dogleg on a low cowl car.
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
High cowl car
William L Vanderburg
1922 Center Door Sedan
