Safe cranking technique
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Jan 23, 2026 5:44 pm
Is this how you do it ?
Get a horse !
Mike Silbert
Last Name: Silbert
Re: Safe cranking technique
Post by Mike Silbert » Fri Jan 23, 2026 6:40 pm
Here are 2 video examples from fellow poster Steve Jelf of how to crank a Model T
https://www.youtube.com/watch?v=3pv6HWWOGYA
https://www.youtube.com/watch?v=B_lkFGQToIw
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Jan 23, 2026 7:09 pm
For Petes sake its a joke.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Fri Jan 23, 2026 7:14 pm
REALLY high compression head?? :lol:
Last Name: Hjortnaes
Post by DHort » Fri Jan 23, 2026 7:28 pm
Gonna split his pants and then what?
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Fri Jan 23, 2026 8:03 pm
I’ve seen worse attempts.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Fri Jan 23, 2026 10:06 pm
Video #2 I sent is a demonstration of a worse attempt.
Or how you can hurt yourself doing it wrong.
Those guys look like they are working really hard trying to hurt themselves.
I don't know if Steve made it as a warning or as a joke.
I take it as both plus a reminder of the danger when things are wrong.
Maybe he will answer with the background of the video.
Mike
dykker5502
First Name: Michael
Last Name: Deichmann
Post by dykker5502 » Sat Jan 24, 2026 8:22 am
#1 is made to show how easy a model T is started by hand crank when it is in proper state.
No need to wind the handle likecrazy.
Ford Model T 1914 Touring
Post by TXGOAT2 » Sat Jan 24, 2026 11:01 am
After performing proper starting preparations, one should "lift" the crank with moderate vigor. Good maintenance and correct technique will assure success while avoiding broken bones, damaged teeth, and split britches. If it is found that the engine needs to be "spun" in order to clear a flooding condition, turn the ignition off first.
Post by Steve Jelf » Sat Jan 24, 2026 11:35 am
#2 demonstrates that with correct pulling, a kickback is harmless. I broke a wrist by cranking a tractor the stupid way, and that was a serious reminder that correct cranking matters.
