Autolite spark plug number
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Mon Jan 26, 2026 11:25 pm
What is the Autolite spark plug number for 1/2" thread base plugs? I have seen three numbers: F11 , #25 , and 3095.
bobt
Last Name: Thompson
Re: Autolite spark plug number
Post by bobt » Tue Jan 27, 2026 6:40 am
O'Reiley auto parts under $5. Autolite 3095 I ran them for the last eight years. bobt
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Jan 27, 2026 10:27 am
Sparkplugs.com
3095 $5.80
425x. $31.95
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Jan 28, 2026 12:14 am
Thanks to both of you. I knew Champions had gone out of sight. I still have some NOS Champion A-25's. I wonder how they compare to Autolites?
Post by DanTreace » Wed Jan 28, 2026 8:22 am
Just one potential problem with Champion 25 is the electrode is just threaded into the ceramic and potted to the porcelain.
If you use more than finger tight on the thumb nut on the terminal, the potted electrode can be broken away inside and lead to hidden misfires.
Run the 25 in the Prus head and they work fine, normally gap at .025" as run on Ford magneto and good results.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Jan 28, 2026 12:14 pm
Dan, Would there be a difference between Champion A-25's made at different decades? Is the electrode threaded on all of them? My box of NOS Champion A-25's were made in the 1950's or 60's, at the latest, and I never noticed the electrode issue. The have A-25, not just 25 on the porcelain and have more ribbing on the porcelain, If I remember correctly, but its been years since I looked at them.
Post by Mark Gregush » Wed Jan 28, 2026 12:25 pm
My experience with the 25's was the same as Dan's. Mine were from the 90's.
Last Name: Hatch
Post by Dan Hatch » Wed Jan 28, 2026 12:54 pm
Terry what color are the bases on your A-25? They are take apart right?
I have some I got in the 60’s that are cad plated. The 50’s ones I got are black or blued. Dan
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Jan 28, 2026 2:14 pm
As best I remember, the bases were cadmium take a parts.
Post by TXGOAT2 » Wed Jan 28, 2026 2:19 pm
I've had a few of the terminals come loose from the insulator. I don't remember exactly what plugs they were. My car has "Silvery plated" Champion A 25 plugs in it. They have performed very well for over 15,000 miles.
Tmooreheadf
Last Name: Moorehead
Post by Tmooreheadf » Wed Jan 28, 2026 9:11 pm
Anyone had trouble with 3095 plugs leaking compression at the top metal crimp where it contacts the porcelain on the OD?
Post by TXGOAT2 » Thu Jan 29, 2026 10:54 am
Are you sure it's a compression leak? Leaks at that point are unusual. Gray to black deposits are common on plug insulators, especially where rubber boots are used on the plug wires. It's caused by high voltage corona and will usually wipe off easily.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Wed Feb 04, 2026 10:59 am
Yes ,compression and unburned fuel , that is why I quit using them. The 1's made in the USA didn't do this, but the last set i bought were mexico made and they leaked between the porcelain and metal. I found some nos AC spark plugs, haven't looked back.
BUT with the recent bankruptcy filings AUTOLITE and other names will be going away for good.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Sat Feb 07, 2026 12:04 pm
I took a screenshot from a video of this Motorcraft plug. It was arcing on top between the porcelain and threaded section. That’s the only problem I’ve ever had with them.
Post by John kuehn » Sat Feb 07, 2026 6:35 pm
Motorcraft 465 works OK. Ford is introducing a 465A that’s supposed to be an improvement.
