Stewart speedometer
BillM
Topic author - Posts: 30
- First Name: BILL
- Last Name: MAULDIN
- * REQUIRED* Type and Year of Model Ts owned: 1923 Coupe
Stewart speedometer
Am I correct that this swivel is made In October 1919 and is a 6:1 ratio? If so would it be correct to use on a 1923 coupe?
Re: Stewart speedometer
Russ Furstnow is the speedometer guru (He wrote the book.). If he doesn't see and answer this post, maybe you can contact him through the forum (or Google).
I believe that is a left hand drive & the ratio is 2 & 1/2 to 1.
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
The Stewart Model 1962 swivel is a 6:1 RH ratio. It goes on a 1915-17 Hudson. You need a Model 1913 Stewart swivel for your Ford. I hope this helps. Russ Furstnow
Thanks for the correction, Russ - I was under the impression that Stewart swivels were 2 & 1/2 to 1.
BillM
- First Name: BILL
Thank you for that information Russ! I'll be on the lookout for a 1913.
On our RHD cars, the swivel is often mounted on the other side to the LHD cars.Same ratio as the pn 1913 but opposite rotation. If you can't find a decent 1913 swivwl, and your cable and housing is long enough, the swivel can be mounted on the opposite side of the car. Without getting into my spares, I cannot recall the PB for this alternative swivel. Perhaps Russ knows.
Russ_Furstnow
- First Name: Russ
Nearly all of the pot metal Stewart swivels look alike, but there are a variety of ratios (from 1:1 to 12:1) and RH and LH types. The 2.5:1 LH part number is Model 1959. Most applications take the Model 1913. I hope this helps, Russ Furstnow
BillM
- First Name: BILL
Yes it helps a lot. I'll find one somewhere. At least now I know what im looking for. I really appreciate your help guys!
A questions for Russ. The Stewart potmetal swivel housings are the weak link in the Stewart swivels I have found. Can components from LH swivels be swapped into RH swivel housings? Are swivels housings for different ratios interchangeable for other ratio components. This may/may not enable a good swivel to be mix and matched from models.
In my experience, the pot metal housings are interchangeable.
Russ_Furstnow
- First Name: Russ
John is correct. The pot metal housings are identical. The inner gears determine the ratio of the unit. I have new sets of gears that turn any Stewart swivel into a 2.5:1 RH swivel. These new gear sets were manufactured using original Stewart gears as a pattern. I hope this helps, Russ Furstnow
BigAl
- First Name: Alan
- Last Name: Stein
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Bill, Sent email through the forum.
Thanks for the confirmation re parts swapping Russ. i suspected it was the case. I guess then that the only difference of consequence is the threaded lower half and the lock nut on the later housings rather than the plain pin with the pressed on collar.
Your spare gear sets will undoubtedly keep many users happy.
Harley_97
- First Name: Roger
- Last Name: Hallett
- * REQUIRED* Type and Year of Model Ts owned: 1924 Runabout, 1917 Runabout
I got this Stewart gear with some T items I bought awhile back. I don't see any signs that it has ever been used. The question, is this gear for Model T's or something else.
Thanks Roger
Thanks Roger
Russ_Furstnow
- First Name: Russ
The gear is a 16T9P (#2302) pinion gear. It was not used on a Ford but some other automobile. The Ford uses a 16T8P pinion gear (#2301). I hope this helps, Russ Furstnow
Harley_97
- First Name: Roger
Thanks Russ.
