Magnet Clamps
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Magnet Clamps
Post by ABoer » Mon Feb 02, 2026 10:41 am
Hi All ;
Can you tell me what are the best Magnet Clamps ?
Thank for your answer .
Toon
Last Name: House
Re: Magnet Clamps
Post by George House » Mon Feb 02, 2026 11:14 am
I think “the Best Magnet Clamps” would be the one compatible with your 16 magnets. I use your ‘A’ clamp for engines 1914-1926.
Re: Magnet Clamps
Post by speedytinc » Mon Feb 02, 2026 11:19 am
I think using the wider clamp (C) will give you a smaller dead spot between nodes.
A is the more common clamp. I see no advantage to B
Re: Magnet Clamps
Post by TXGOAT2 » Mon Feb 02, 2026 11:28 am
According to a Ford Service Bulletin of January, 1924, recharging magnets in the car can only achieve about 60% of full strength. For full original magnet strength, the magnets have to be removed and individually recharged, or replaced with new ones.
Mike Silbert
Last Name: Silbert
Re: Magnet Clamps
Post by Mike Silbert » Mon Feb 02, 2026 11:38 am
For me the best clamp is "A"
I have them, and they generate more than enough magneto power for my needs.
I have never noticed (or measured for) any real world performance difference in the types of clamps.
Unless I built the engine I don't even know what type is in there.
It would take a setup like The "Franken-Tester" to tell what realistic facts are.
viewtopic.php?f=2&t=51653
I am curious to know if there is a measurable difference.
Mike
Re: Magnet Clamps
Post by Scott_Conger » Mon Feb 02, 2026 12:01 pm
Each magnet clamp was associated with a specific coil assembly design - each one being different. A team of engineers, each knowing far more about their design than I, decided at the time what that mag coil shape and magnet clamp shape should be.
Since the last magneto design (corresponding to part "A") was the most powerful magneto produced, I'd say they knew what they were doing.
If it was my rebuild, the choice of magnet clamps would be decided upon by the year of the car and the specific style of mag ring that it was going to be used with.
Re: Magnet Clamps
Post by TXGOAT2 » Mon Feb 02, 2026 12:42 pm
Besides the shape, the composition of the steel may differ from one type to another.
First Name: Adrian
Last Name: Whiteman
Re: Magnet Clamps
Post by A Whiteman » Mon Feb 02, 2026 1:51 pm
given that lower cost was the goal their aim would be to reduce the manufacture cost even by 'shavings', hence A won out in the end.
Toon, I doubt you would notice much, if any, difference in performance between each design 'in the real world'.
All the best.
Re: Magnet Clamps
Post by speedytinc » Mon Feb 02, 2026 2:17 pm
A was used for the highest output magneto(15) thru to the end. 15 had the double stack coils & the improved, taller magnets. Output was increased to power the new electric lights.
From this point changes were made to the field coils only, supposedly as cost savings measures. Next field coil iteration used a wide single stack, then to narrower stacks.(thinner coil stacks, less copper.)
Depends on your goal. Do you want to be 100% original to the year of the motor or do you want max output?
browning
First Name: David
Last Name: Kahle
* REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
Re: Magnet Clamps
Post by browning » Mon Feb 02, 2026 5:24 pm
I just happened to have a spare set of magnet clamps like the "C" pictured so I did a quick voltage test with the stock flywheel and the "A" clamps and then changed just the clamps and retested with the Franken-Tester using the same magneto and magnets. The "A" clamps outperformed the "C" at all three tested speeds. At 500 rpm the test results were 10.6 volts vs. 10.2 volts. At 1000 rpm the results were 20.35 volts vs. 19.76 volts. At 1500 rpm the results were 29.35 volts vs. 27.9 volts. Another revelation was that the older style clamps were much more prone to bending, making the alignment more difficult and at the same time were more difficult to position since the alignment lugs were on the outside of the magnets rather than just on the space between them. Nothing to gain by using the earlier clamps, apparently.
Mike Silbert
Last Name: Silbert
Re: Magnet Clamps
Post by Mike Silbert » Mon Feb 02, 2026 9:06 pm
David,
Thank you for running the tests.
Nothing beats a heads to heads test with apples to apples comparison data.
Good, bad or indifferent is sometimes hard to find.
Seat of the pants data will only get you so far.
Mike
browning
First Name: David
Last Name: Kahle
Re: Magnet Clamps
Post by browning » Mon Feb 02, 2026 9:34 pm
Mike, My pleasure, the fun is seeing the honest data in place of suppositions or second hand stories. Well meaning “experts” sometimes requote incorrect opinions. I have had several experts explain to me that i had the steering wheel on upside down. Best to smile and go on.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Re: Magnet Clamps
Post by AndreFordT » Tue Feb 03, 2026 2:42 am
In the Judging Guidelines 4th edition under the section "All the Same" pages 87 to 91 you can find some information about the coilrings the magnets and the clamps.
As I understand (English is not my home talk) the clamps change is following the magnets and the coilring changes. Each kind of clamps go with his kind of coilring and magnets.
To test them, You will need to assemble the right clamps with the right coilring and the right magnets.
As I rebuild a few of coilrings of 1910 to 1927 may experience tells me that the right clamps with the right magnets and the right coilring works very well. You just need to pay attention on the round remountables, The core centers are a few degrees advanced compairing them with the later coilrings. (They are called: "The arm brakers.")
Just my opinion.
Andre
Belgium
Re: Magnet Clamps
Post by speedytinc » Tue Feb 03, 2026 8:07 am
Nice to have a test bed for such experiments.
I have to ask if all variables were accounted for.
Are the earlier magnet plates the same thickness as the later style?
If thinner, did you compensate for the clearance gap between the magnets & field coil?
browning
First Name: David
Last Name: Kahle
Re: Magnet Clamps
Post by browning » Tue Feb 03, 2026 12:10 pm
I just redid the flywheel with the newer style clamps. Both styles measure .118 to .121 thick.
Re: Magnet Clamps
Post by TXGOAT2 » Tue Feb 03, 2026 12:22 pm
Metallurgy may differ. Plates that have been bent and straightened will be somewhat hardened, which may affect their magnetic behavior. Soft steels magnetize easily, but will not hold magnetism well. Harder steels and steel alloys will hold magnetism. Field pieces uses in association with permanent magnets are usually very soft steel.
