Late "T" Tire Valve Stem & Hardware
careese@vcu.org
First Name: Charles
Last Name: Reese
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster
Post by careese@vcu.org » Tue Feb 03, 2026 8:02 pm
Would like to communicate with anyone knowlegable with the late Model T (and early Model A) innertube valve stems:
Schrader 777, 888, 6300
Dill VS6, VS74[no TR16], VS 74, TR 16 VS 74, and VS-74A
Trying to understand the transition from Model T (wood spoke wheel), through the late Model T (wire spoke wheel), to the early Model A.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Late "T" Tire Valve Stem & Hardware
Post by Humblej » Wed Feb 04, 2026 8:16 am
Good discussion on the forum last summer about this.
viewtopic.php?f=2&t=48694&p=367582#p367434
Post by Original Smith » Wed Feb 04, 2026 11:04 am
It really helps to know the year of your car! I'm upset with the current availability of correct valve stem hardware. I use old stock correct items, and have no trouble. The big tire companies don't care what is correct.
Post by Original Smith » Fri Feb 06, 2026 5:51 pm
Even though Ford used 777's from the factory, I have found 888's to be a perfect replacement, and less weight too.
