Antifreeze
LeviSara
First Name: BryceLevi
Last Name: Rinkhoff
* REQUIRED* Type and Year of Model Ts owned: 1923 Tudor & 1927 Tudor
Antifreeze
Post by LeviSara » Wed Feb 04, 2026 9:44 pm
Hello there! Can I use red 50/50 OAT antifreeze in the 1927 model t?
Re: Antifreeze
Post by Scott_Conger » Wed Feb 04, 2026 10:18 pm
Personally, I would not
I'm going to guess that the vast majority of "T" owners run "green" coolant and if I ever needed to borrow coolant when in a group or on a tour, "green" is what you're very likely going to be offered.
the two do not mix and there is no technical benefit of OAT over standard coolant since there is no aluminum in the "T" cooling system that needs protecting
Mike Silbert
Last Name: Silbert
Re: Antifreeze
Post by Mike Silbert » Thu Feb 05, 2026 12:06 am
No, I would not, do not, do not recommend using it.
Use only coolants that are labeled for older vehicles and these are IAT coolants.
The old school green stuff.
Don't trust me, trust what the manufacturers say:
https://www.valvolineglobal.com/en-ksa/ ... -coolants/
I won't use DexCool either due to it causing gasket failures
https://www.classlawgroup.com/gm-dex-cool-settlement
https://www.reuters.com/article/busines ... N27350115/
https://bobistheoilguy.com/forums/threa ... it.110944/
The green stuff works fine in all vehicles but it needs to be updated, flushed on a regular basis to keep it's corrosion protection good.
Mike
Re: Antifreeze
Post by TXGOAT2 » Thu Feb 05, 2026 10:45 am
"Green" antifreeze, used as directed, is best for Model Ts and other pre-1975 vehicles.
NoelChico
First Name: Noel
Last Name: Chicoine
Re: Antifreeze
Post by NoelChico » Thu Feb 05, 2026 11:06 am
Does having an aluminum head influence the decision? Just asking.
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: Antifreeze
Post by big2bird » Thu Feb 05, 2026 11:13 am
The newer green stuff is compatible with aluminum.
Re: Antifreeze
Post by TXGOAT2 » Thu Feb 05, 2026 11:13 am
Green anti-freeze is fine for aluminum heads. Buy a name brand, and use as directed. Adding a properly designed overflow tank to the system might help prevent corrosion by limiting air/oxygen access to the coolant.
Re: Antifreeze
Post by TXGOAT2 » Thu Feb 05, 2026 11:14 am
"Unviersal" anti-freeze is being sold today. It is labeled as compatible for all vehicles/all years.
Re: Antifreeze
Post by Scott_Conger » Thu Feb 05, 2026 11:18 am
Noel
if you read what Mike posted, the green coolant protects cast iron, brass, copper and aluminum from corrosion. Not mentioned, but importantly, it protects the lead solder from being attacked as well.
the newer OAT specifically does NOT protect brass or copper from corrosion and the lead solder will definitely be attacked.
I think that in itself should answer your question.
Folks can play games with other coolants like OAT and Universal Coolants (Hybrid OAT) but at $1600 a pop, my radiator is going to get (green) coolant that was designed to protect it. I also know that corrosion protection ceases after 2-3 years, so it gets replaced periodically.
As far as aluminum head corrosion, my experience has been that generally it happens when you run 10 year old coolant (8 years after it quit protecting against corrosion) or you have oil-soaked wiring pinched somewhere on the frame. You can test coolant for electrical current in the mV range. I had such a car which was eating up an aluminum radiator cap FAST. Updating the wiring stopped that problem in its tracks.
The newer OAT coolant lasts for years and years and as such, goes well with a generation of children who are in a great many cases, afraid to drive, and if pushed to actually get behind the wheel, would never conceive of opening the hood to see what was under it. Leave that up to the older UBER driver.
Re: Antifreeze
Post by Allan » Thu Feb 05, 2026 10:20 pm
Are there places in the USA where antifreeze is not necessary, like southern California.
I use clean water and a cup of soluble oil to limit corrosion.
The green stuff does the same, but will also find the tiniest leak anywhere in the cooling system.
