Need to lower steering unit 1913 speedster.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Thu Feb 05, 2026 12:43 am
Does anyone still make or have a set of steering unit tapers? Venders used to supply them but have not found any. Any ideas??
answer me here its quicker.
thnx,
frontyboy
AndreFordT
First Name: Andre
Last Name: Valkenaers
Re: Need to lower steering unit 1913 speedster.
Post by AndreFordT » Thu Feb 05, 2026 5:32 am
Chaffin Garage 3500CW steering column collar and wedge.
Andre
Belgium
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Thu Feb 05, 2026 8:15 am
Rootleib still has them listed in their catalog.
Maybe they have them in stock.
Mike
Post by Allan » Thu Feb 05, 2026 5:04 pm
Speedsters are, in the most, custom builds. As such, the best fit may be a custom made item. It is not hard to make an aluminium wedge to suit your particular application.There is nothing quite like having a go at it.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Feb 05, 2026 5:23 pm
I just fabricate and machine my own for a proper fit.
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Thu Feb 05, 2026 5:31 pm
I have a set of those aluminum steering wedge set ups that will not be using. I will not be back to my shop until April so it you can wait till then I will round them up and take pictures.
Mike
frontyboy
First Name: dick
Last Name: dock
Post by frontyboy » Thu Feb 05, 2026 8:43 pm
Hi Mike,
I can wait as I have lots to do yet. April is not problem.
thnx
frontyboy.
YellowTRacer
First Name: Ed
Last Name: Archer
Board Member Since: 2009
Post by YellowTRacer » Fri Feb 06, 2026 4:54 pm
In old #4 the original was made out of hardwood. It was probably usable as is but we just duplicated it out of hardwood. Simple and easy.
Ed aka #4
Post by Allan » Fri Feb 06, 2026 5:30 pm
So, using a ready made wedge will dictate where the column ends up sitting. That seams a little backwards to me.
My Duncan and Fraser built wide body roadster came with a lowered steering column which was also displaced outwards, from the factory where it was built. Having done a few, no doubt they could make the wedges beforehand, ready to go. But, the first one had to be a custom made one. Along with the wedge, the steering column flange features a wooden doughnut of quite complicated dimensions, thicker at the top and thicker on one side. The hole in the original steel firewall was closed and a new rectangular one cut lower down and displaced 3/4" to the outside. No doubt they had developed a template to cut the hole and drill the column bolt holes.
Post by TRDxB2 » Fri Feb 06, 2026 6:42 pm
Here are some methods
