Removing front seat cushion 27 touring
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Post by Dave1 » Tue Feb 10, 2026 6:18 pm
How does one remove the front seat cushion ( back) on a 27 touring?
This one was recently re upholstered, looks like the covering is stapled in place, if so does this require pulling all the staples and then replacing them?
Mike Silbert
Last Name: Silbert
Re: Removing front seat cushion 27 touring
Post by Mike Silbert » Tue Feb 10, 2026 6:54 pm
Dave,
The "Cushion" (bottom spring) just sits in there
The "Backrest", Ford Called it "Seat Back Cushion" (vertical back spring) is built into the seat frame and hangs on straps or screwed in place then the upholstery is installed over it trapping it into place. Originally they were tacked in place but today on most hidden locations it is stapled in place.
Basically they are built in.
To change them is quite a job.
Mike
Dave1
Last Name: Eddie
Post by Dave1 » Tue Feb 10, 2026 7:17 pm
Thanks, initially I am looking at removing some padding from the front seat, think I talk to an upholstery shop
Jevil
First Name: Jens
Last Name: Willeke
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor Sedan
Post by Jevil » Wed Feb 11, 2026 7:31 am
I have nearly completed all the re-upholstering in my '27 Tudor.
I worked back to the springs, repainted what was still useable.
The drivers seat spring was too damaged and the new one was in the mail yesterday.
Then I applied new cushions and sewed the upholstery with a period correct fabric.
Will show the photos soon.
Removing staples was a big part of work. Quite difficult because it was not only the the stuff from the last re-upholstery but also the original fabric underneath.
1927 Tudor Sedan - black (of course)
Mopar_man
Last Name: Govoni
Post by Mopar_man » Wed Feb 11, 2026 12:21 pm
Take a look at my thread Getting Rattles back on the road. I have the complete upholstery job on a 26 Touring.
