Problem fitting standard adjustable lifters
1915ford
Last Name: Cameron
Post by 1915ford » Wed Feb 11, 2026 10:29 pm
Doing a full rebuild on my 22 centerdoor engine. Everything shows minimal wear so i ordered standard adjustable lifters. The problem is they wont go into the block. They seem to be one or two thousandths too big. Suggestions? Is there a reamer out there that would work for this?
Re: Problem fitting standard adjustable lifters
Post by Scott_Conger » Wed Feb 11, 2026 10:40 pm
I would start with:
what exactly is the diameter of the lifters?
what exactly is the diameter of the lifter bores?
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Feb 11, 2026 10:49 pm
Fairly common. Tooling wore and the factory put undersize lifters in instead of replacing the tooling (or they made the guides undersize to use up undersize tappets). I’ve seen it probably about a dozen times. Run a 7/16” reamer thru the guides to take them from undersize to “standard” and your “standard” lifters will fit fine. There are a bunch of parts like these when you get into blueprints in the archives. They generally say something to the effect of “use when …. is undersize/oversize”.
jsaylor
Last Name: Saylor
Post by jsaylor » Thu Feb 12, 2026 3:49 am
Before you start reaming out the block, follow Scott's advice and measure the new lifters and make sure the vendor sent you the correct ones.
1915ford
Last Name: Cameron
Post by 1915ford » Thu Feb 12, 2026 9:39 am
Thanks Adam. Thats exactly what i needed to know.
Last Name: Hatch
Post by Dan Hatch » Thu Feb 12, 2026 10:03 am
Measure twice, cut once. That hold true here as well.
Chris Bamford
First Name: Chris
Last Name: Bamford
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster 1926 Touring
Post by Chris Bamford » Thu Feb 12, 2026 11:59 am
I cut this damned board twice, and it’s STILL too short!
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Thu Feb 12, 2026 4:08 pm
Mark, see if a local machine shop can hone the lifter bores for you instead of reaming.
It has been my experiences that most chucking reamers need a minimum of about 2% of the diameter (-in this scenario about 8 thousandths) to keep the flutes loaded during the cutting process. Otherwise, you generally get chatter marks in the bore finish which will lead to galling. Any performance machine shop should have a Lifter Hone, and likely two or three strokes will size them for your new lifters. If you cannot find a shop, then order a set of 0.015" over tappets (0.452) and purchase a 0.4535" Reamer from McMaster, and that should put your tappet clearance to around 0.0015 which should be perfect.
