What have you done to your Model T in February '26
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Fri Feb 06, 2026 8:14 pm
Removed mosquitoes.
Vern (Vieux Carre)
Re: What have you done to your Model T in February '26
Post by RajoRacer » Fri Feb 06, 2026 8:33 pm
Hope the wife's Christmas ornaments aren't out there like my wife's are !!!
Daisy Mae
First Name: Kurt
Last Name: Andersson
Post by Daisy Mae » Fri Feb 06, 2026 8:39 pm
I have my 24x40 3 bay shop...
Then I have a 12x24 storage shed for yard stuff, bikes, Xmas, boxes of stuff etc.
The shed showed signs of rodents...
Guess where my wife insisted the Xmas stuff was to be stored this year...
I tried to protest...it didn't work....
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sat Feb 07, 2026 11:42 am
. I've accidently fumigated my garage a few times only to have insurance that my carbon monoxide monitor is working
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sun Feb 08, 2026 6:10 am
Actually, the other day, I finished rebuilding a different engine, different car off camera, not the Model T pictured. When I got the car running, first start, I turned around and saw the photo opportunity above. All the oil and assembly lube burned off. This is rented space, not mine. I started up the Model T, first try, and moved it out of the way to get the other car on the road and air out the garage. Then drove the T back into its spot.
Vern (Vieux Carre)
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Sun Feb 08, 2026 5:52 pm
I’m about ready to drop my motor in a speedster I’m building. I’ve got the front and rear axles done, next comes the body. It’s an Overland body but I might want to go for a spin before I take it off for bodywork and paint so I had to drill holes for a coil box. Never used one of those step bits before.
MossPointMachine
First Name: Stephen
Last Name: Capdepon
* REQUIRED* Type and Year of Model Ts owned: 25 T truck
Post by MossPointMachine » Sun Feb 08, 2026 6:16 pm
Pulled wooden truck body from the 25 my Dad passed on to me. Sheet metal mostly painted and Dad was building the engine when he passed away 2 years ago. Finishing up the engine and playing around with front half touring car on the frame. Wheels are NOS Fords dad bought years ago.
Post by speedytinc » Sun Feb 08, 2026 6:29 pm
Dont leave your engine sitting horizontal.
That puts a big strain on the crank from an unsupported transmission. Tip it up vertical.
MossPointMachine
First Name: Stephen
Last Name: Capdepon
Post by MossPointMachine » Sun Feb 08, 2026 7:28 pm
Yes thanks for that, I just bored the fourth main and installed it with engine vertical.
tiredfarmer
First Name: leonard
Last Name: simunek
* REQUIRED* Type and Year of Model Ts owned: 1926 touring. 1931 model a pickup, 1947 willys cj2a
Post by tiredfarmer » Wed Feb 11, 2026 5:51 pm
Today I checked the coils on my 26 Touring and also checked the sparkplugs. Later I will clean the timer and clean the air filter. getting ready for spring and warm weather.
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Wed Feb 11, 2026 6:57 pm
This is the first year that I didn't put our 11 T on jacks for the winter. I'm glad that I didn't, as it was in the mid 70s yesterday so I took it out for an early February drive.
Brent Mize
First Name: Brent
Last Name: Mize
* REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Post by Brent Mize » Thu Feb 12, 2026 5:50 am
Today we hung the front fenders on our 27 Sport Touring.
It’s starting to look like a car!
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Thu Feb 12, 2026 9:11 am
Living in WI i have not done much with my Ts they are all in storage. But 2 of mine celebrate their build days. My 27 turns 99 next week and my 16 turned 110 last week. Neither car has changed much since they were built especially the touring. It's still rock its orignal interior and wheels the engine has never had main or even a valve job done in all its years and still runs very well.
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Thu Feb 12, 2026 9:23 am
Nothing lately, she’s still taking her winters nap.
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Thu Feb 12, 2026 11:23 am
Wow that's a nice paint job! Info regarding it?
TFan
First Name: Jim
Last Name: Riedy
Post by TFan » Sat Feb 14, 2026 8:38 pm
Got some bling for the old feller, another week of this heat wave and it might be warm enough in my building to put them to use. Chaffin's does really nice work, My thanks to them. Jim
Maineiac
First Name: Michael
Last Name: Whalley
* REQUIRED* Type and Year of Model Ts owned: A 1924 TT project, that started as a stripped chassis.
Post by Maineiac » Mon Feb 16, 2026 7:38 pm
Rebuilt the $10 headlights and gave them a lick of paint.
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Sat Feb 21, 2026 1:08 pm
I was able to salvage my four dip pan that came to me with bolted on repair ears. I had a rusted out three dip pan that had the correct three rivet ears and I used a frame checked for square to align everything before tack welding them in place so I could remove the bolts and rivet and braze.
While inside my engine I took a better look at my drums. The reverse had a hairline crack across one of the webs and my low speed had rivet marks and other wear on the OD. I ordered three drums from Dave Nolting and used a centerdrill to remove the old riviets and my press to reset the rivets. I am delighted these quality replacements are available versus salvaging old drums.
Tom Miller
BaltimoreTMan
First Name: Alex
Last Name: Ashman
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster, 1922 Canadian Touring
Post by BaltimoreTMan » Thu Feb 26, 2026 11:55 pm
What have I done to my Model T in February’26? Pulled the motor for a total rebuild! Looks like I forgot to drain the oil before yanking the crusty 4 banger out…. My car has a build date of August 23, 1926. It’s titled as a 1926 but I believe it’s a 1927. I’ve already rebuilt the Vaporizer carburetor, recored the radiator, and repainted the hood pieces and new old stock hood shelves, as well as repainted the radiator shroud. Next is to do body work and paint on frame and fenders, rebuild the motor and transmission. Im slowly restoring the car from front to back! Thanks to Nathan for helping me tonight pull the motor. Also thanks to my good friend Mike Silbert for giving me last minute advice on dropping the wishbone to get more clearance! The best time to work on T’s is in the still of the night in a cold unheated garage… haha!
Let’s see if I can get this car on the road by August 23, 2026 for its 100th birthday!
-Alex
BaltimoreTMan
