Himico manifold install
csnailnrun
First Name: Ryan
Last Name: Snellen
* REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
Post by csnailnrun » Tue Jul 09, 2019 9:49 pm
Who is running a Himico manifold that can share if there is special install hardware? Fine thread hex bolts seem to be ok but the outer portions of the manifold is a similar dimple of a standard manifold. Maybe too innermost where the intake comes up. Any advice?
Ruxstel24
Last Name: Hanlon
Re: Himico manifold install
Post by Ruxstel24 » Tue Jul 09, 2019 10:28 pm
I had a Wilmo, kinda sorta like that.
It used the studs and straps like a stock setup.
That's the only way to get pressure on the center ports. Just standard rings/glands.
I actually have/had bolts...
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Wed Jul 10, 2019 8:30 pm
Standard clamps do not work for this manifold.
Any other suggestions?
Post by Mark Gregush » Thu Jul 11, 2019 10:33 am
If the area where the stud comes thru on both sides is the same height;
The Model A used an extra thick washer in this area. They are concave on one side so only the edge put pressure on the mounting. The only problem I could see using those is the Model A stud is 7/16 and the T 3/8. The hole would be a little big but might work.
https://www.snydersantiqueauto.com/Prod ... hByKeyword
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Thu Jul 11, 2019 11:14 am
Great tip Mark!
