Good source for Wooden Steering Wheel Rims
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Sat Feb 21, 2026 11:18 pm
Anyone know a good source for wooden steering wheel rims, such as on early Ford cars, or Model T's? The kind that nest into the 4 spider spoke ends, and are held in place with a screw on each arm of the center spider? I need to find a source for a wooden rim for two 1912 Overland automobiles. The original deteriorated rims were wood, and are just 1/2" larger in diameter than a Model T steering wheel rim, so I cannot use a Model T wood steering wheel, but they are virtually identical in style and shape of the wood rim area. Anyone know someone who made a Model T wood rim for them, and could make a slightly different size?
Thanks to all!
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Re: Good source for Wooden Steering Wheel Rims
Post by South Park Zephyr » Sat Feb 21, 2026 11:54 pm
Do you have a diameter?
I have a few wooden wheels that are not T’s
Scott
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Sun Feb 22, 2026 7:00 am
Snyders carries a good selection of finished steering wheels. Maybe they can help you?
gldavis
Last Name: Davis-Williams
Post by gldavis » Sun Feb 22, 2026 7:08 am
I bought a steering wheel from this vendor several years ago, and I've been very happy with it.
https://woodbykevinallen.com/model-t-st ... heels.html
George Davis-Williams
Lake City, MI
1926 Tudor
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Sun Feb 22, 2026 9:52 am
Noah Stutzman can also make wooden steering wheel rims. Years ago he told me if I bring him the metal spider, he can go from there.
It’s also fairly easy to make your own by cutting 16 pieces of wood and gluing them with overlapping joints. I made it round by using a router bit and a turntable on my drill press.
Tom Miller
South Park Zephyr
Last Name: Francis
Post by South Park Zephyr » Sun Feb 22, 2026 1:19 pm
I have these that are not Model T wheels if they might be what you are looking for
Scott
South Park Zephyr
Last Name: Francis
Post by South Park Zephyr » Sun Feb 22, 2026 1:21 pm
One more that wouldn’t fit with the previous post
Scott
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Sun Feb 22, 2026 2:42 pm
I have had good luck with Kevin Allen , at Wood by Kevin Allen , he does excellent work and can make a custom wood wheel to fit your stock steering wheel spider, provided you have a spider for your car that you can send him. I see that Kevin’s contact information has already been posted in this thread, so check above for that information .
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Sun Feb 22, 2026 3:09 pm
Noah Stutzman. Makes steering wheel wooden rims. Made from a single piece of steam bent wood with a finger joint. He can make them round, oval with or without finger grips. Excellent Amish craftsmanship. Stutzman wheel shop 330 897 1391, Baltic, Ohio
Tmooreheadf
Last Name: Moorehead
* REQUIRED* Type and Year of Model Ts owned: 24 Touring, 25 Coupe,
Post by Tmooreheadf » Sun Feb 22, 2026 7:38 pm
I agree with Jack. Noah has done two for me. His work is great. He let me select the wood I wanted. Sent the spider to him and he did the rest! Outstanding service and quality!
