1925 frame
Oldrusty26
Topic author - Posts: 94
- First Name: Travis
- Last Name: Melnick
- * REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT 25 runabout many misc projects
- Board Member Since: 2012
1925 frame
I’ve been trying to figure this out but my question is , h only difference between a 24 and a 25 frame is the emergency brake pawl bracket has two bolts instead of 4 , am I correct , or are there other things to look for ?
Re: 1925 frame
Yes, some time in 1925 model year the quadrant had only 2 holes, but the frames continued for a time with the std. 4 holes till perhaps the Improved Car frame in Aug 1925.
Note the 4 holes (one is filled with a bolt), but from the factory the quadrants were riveted in place, Ford didn't use bolts for the quadrant.
1925 frame pictured, factory rivets on the new 2-hole quadrant.
Oldrusty26
Re: 1925 frame
Thanks dan !! Everything else is the same ? I have a 25 frame in my parts pile , it’s not a huge deal to change it as I’m not that far with this build , but I also have a two hole quadrant that is off so all I’d have to do is robot or bolt it on .
Oldrusty26
Re: 1925 frame
Rivet or bolt on , sorry
Re: 1925 frame
Didnt Ford keep using the 4 hole frames until the frames were used up when the 2 hole frames were being introduced?
Ford usually used older design parts until they were used up. Thanks for any info about that.
Mike Silbert
- First Name: Mike
- Last Name: Silbert
Re: 1925 frame
Probably everything you want to know about holes in frames somewhere in this posting.
https://www.mtfca.com/discus/messages/3 ... 1366353153
Mike
Mike
Re: 1925 frame
The expert on this subject is Larry Smith.
Re: 1925 frame
The four hole quadrant frames were used well into the new style two rivet jobs until the frames were used up. The two outer holes are the same distance apart as the old four hole jobs.
Oldrusty26
Re: 1925 frame
Thank you !! I’m going to use the frame and just put on the quadrant that I have as opposed to changing the frame out
Re: 1925 frame
One more check for frame holes just before the quadrant checkOldrusty26 wrote: ↑Mon Feb 23, 2026 2:24 pmThank you !! I’m going to use the frame and just put on the quadrant that I have as opposed to changing the frame out
Re: 1925 frame
Your profile lists a 25 TT. Different animal?
Oldrusty26
Re: 1925 frame
[image][/image]Yes , I’m working on a 25 roadster , the TT was for my father , he passed last year , it’s going to be next on the list . I’m actually working on a few , 26 roadster pick up , 27 Tudor , I have a c cab that I’d like to put together too , lol !! I inherited the hoarder gene from him I’m afraid …
rickd
- First Name: Rick
- Last Name: Duquette
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Re: 1925 frame
Pic of a 1925 two hole frame/two rivet quadrant. This is a July 1, 1925 Touring. I've owned this car since 1998, found it on a farm a little south of the town I live in.
