Model T TT 5th wheel or ?
Post by John kuehn » Sat Feb 28, 2026 8:54 pm
Here’s a photo of what looks to me an early version of the so called 5th wheel. If it is was it a company made or was it available from a body maker. Learning something new about heavy TT Truck use.
Re: Model T TT 5th wheel or ?
Post by Allan » Sat Feb 28, 2026 11:21 pm
The clue to that one is on the building. It allows lengths of timber to be carted which otherwise would not fit on a TT, regardless of the weight of the load. Other lumber merchants are likely to have similar units.
Post by Wayne Sheldon » Sun Mar 01, 2026 12:11 am
It appears to be a 1924 to 1927 TT with Ford supplied C-cab. Also equipped with a fifth wheel hitch which was a bit unusual still at that time, and special adjustable trailer for hauling lumber. The trailer axle and wheels with the "crib" for holding lumber slides along the long pole to adjust for the length of the lumber to be hauled.
I wonder what the pole was made of? Wooden pole? Or steel pole?
kelly mt
Last Name: Kelly
Post by kelly mt » Sun Mar 01, 2026 1:26 am
Yes, TT's have 5th wheels.
Post by Jerry VanOoteghem » Sun Mar 01, 2026 7:19 am
The Sibley lumber truck in this article still exists. It was on dispaly at the Piquette Plant for some time.
https://www.autoweek.com/car-life/class ... r-company/
Last edited by Jerry VanOoteghem on Sun Mar 01, 2026 2:18 pm, edited 1 time in total.
PorkChops
First Name: P
Last Name: Chops
* REQUIRED* Type and Year of Model Ts owned: 1924 Tourer
Post by PorkChops » Sun Mar 01, 2026 7:37 am
Interesting to see an early jinker. We used pretty much that same design to haul casing & other oil rig stuff in Indonesia in the 90s.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sun Mar 01, 2026 9:13 pm
As seen @ Hershey 2023
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sun Mar 01, 2026 9:14 pm
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sun Mar 01, 2026 9:15 pm
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sun Mar 01, 2026 9:16 pm
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sun Mar 01, 2026 9:24 pm
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Mon Mar 02, 2026 2:31 pm
5th wheelers were uncommon but not unkown:
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Mon Mar 02, 2026 2:32 pm
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Mon Mar 02, 2026 2:33 pm
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Mon Mar 02, 2026 2:40 pm
I believe this is from Texas complete with aircon? Seen at the Centenary rally.
Junk poor
First Name: D
Last Name: Brown
Post by Junk poor » Mon Mar 02, 2026 3:16 pm
I have been looking for one of these setups for years. Problem is that they take up so much space that most of them got left outside to rot.
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Mon Mar 02, 2026 7:21 pm
I have one of those trailers in as found condition. It is a Fruehauf like the one at the Ford Museum. It is very heavy.
