Tuning Up a Magneto Horn
Monty 98
Topic author - Posts: 30
- First Name: Henry
- Last Name: Hocker
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1920-ish Runabout
After repairing the horn switch & reworking the horn on a '23, I've come to find the horn needs a bit of work. What exactly does the adjusting screw do?
No Bird Soars in a Calm - Wilbur Wright
Re: Tuning Up a Magneto Horn
The adjusting screw on a magneto horn is at the back of the horn trumpet. If you have the back cover off a later battery horn and are loooking at an adjustment screw, the advice will be different.
