26/7 coil box wood
hah
Topic author - Posts: 151
- Last Name: hardiman
- * REQUIRED* Type and Year of Model Ts owned: 26 coupe
26/7 coil box wood
Anyone know what is the original wood in a 26/7 coil box?
Thanks in advance!
John.
Thanks in advance!
John.
Re: 26/7 coil box wood
I don't know, but my guess is any of several common hardwoods would be suitable. It would need to be free from flaws and be kiln-dried and sealed to prevent it from absorbing moisture.
Don't they have a core of vertical wood strips, sandwiched between two venerrs, one on each side?
Aĺlan from down under
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Yup, laminated wood.
Under most circumstances, the best way to refurbish a coil box is to buy the plastic replacement for the wood that is available from vendors.
varmint
- First Name: Vernon
- Last Name: Worley
I don't know what tree was used and I threw away the scrap remnants but I am happy with what I got from the vendors.
Vern (Vieux Carre)
hah
If that’s what you got you got problems, I think! Looks like varmints!
Does anyone know how thick the boards are?
Eric Sole
- First Name: Eric
- Last Name: Sole
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster
I just measured an original and a hardwood replacement kit. They are 1/2" thick.
