Working on my 25 roadster
Oldrusty26
Topic author - Posts: 106
- First Name: Travis
- Last Name: Melnick
- * REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT 25 runabout many misc projects
- Board Member Since: 2012
Ok guys , finally back to working on my 25 roadster , and of coarse I have some questions , I rebuilt the rear axle and installed the bronze thrust washers etc . My question at this moment is how to the turtle decks match up with the body ? The one I have seems like it’s smaller ( narrower ) than the body . Any photos of figment would be helpful , I’ll attach pictures of what I have so far . Are the decks different for a 25 ?
Thanks in advance .
Thanks in advance .
- First Name: Keith
- Last Name: Townsend
Re: Working on my 25 roadster
That looks absolutely correct.
Your fit is going well, just align the deck to the rear tub moldings and the lower deck trim.
Then when you bolt it in place and all is good.
Oldrusty26
That’s my issue , looks like my turtle deck is smaller than the rest of the deck of the car , is there supposed to be a ledge on the sides and rear like my pictures show ? Love that color blue on the photos you sent.
- Last Name: Hatch
Take the deck off and get a real pickup bed. That will solve all your problems. Dan
Oldrusty26
Just may be how the wood subframe was done, if re-wooded from factory, the sheet metal pieces around the wood subframe should have separate ends, just a tiny gap. On yours looks like body filler on the ends? Could be the subframe was made a tad wider?Oldrusty26 wrote: ↑Sun Mar 15, 2026 10:25 pmThat’s my issue , looks like my turtle deck is smaller than the rest of the deck of the car , is there supposed to be a ledge on the sides and rear like my pictures show ? Love that color blue on the photos you sent.
On my project, bought it wooded, with metal already on and painted Ford engine blue, did have to fit new primed panels on the lower side, and rear of the subframe, spent some time fitting each to the wood and squared all up. Note in one photo the old original panel (had rust holes) but used to to locate the 3 holes for the rear fender bracket forging.
Good luck, your project will turn out well too.
Turtle deck bolted down on the subframe flooring.
Originals to show that the turtle deck is rather set back from the subframe sheetmetal anyway, the Ford was the Low Cost auto you know, gaps and fitment weren't priority
Oldrusty26
Thanks dan !!
Oldrusty26
[image][/image]If I use 26 spindles on my 25 will it sit too low in the front or would it not be noticeable enough to matter?
It will be noticeable
Now you have to wonder if you have the correct drag link and tie rod...they both came in different lengths depending on year and configuration. You may well be back here 6 months from now asking "why can't I adjust toe-in?
It's easy enough and cheap enough to buy the correct parts - that would be my choice. And it's my advice.
Oldrusty26
Thanks !! I appreciate it
A true 1925 uses the same front spring as a 1926, which lowers the car about 1 inch. 8 leaf compared to a earlier 7 leaf.
I would be really concerned about the POS battery terminal coming into contact with the battery hold-down.
Oldrusty26
That’s not my battery photo, I do have the correct springs installed . I have different spindles etc , so no issues to change them out , was just questioning the spindle height difference in the stance .
JerryJerry VanOoteghem wrote: ↑Wed Mar 18, 2026 2:35 pmI would be really concerned about the POS battery terminal coming into contact with the battery hold-down.
That is my photo of a '24 I did and later sold. Always have used Optima 6v batteries and make a holder to secure these oblong cases.
The lower holder is a 3/4" thick board with notches to lock into the straps of the Ford battery carrier. Then wood side braces are screwed and wood glued to the base board..... being added to prevent the oblong battery from moving, the upper wood bar then is used to lock the battery in place. The Ford battery box clamps are used to secure the wood bar.
When locked in place the battery won't move.
I learned my lesson as a teen, put a 6 volt battery in the frame and didn't secure it, figured that dang heavy battery would stay put......well it walked just enough to allow the + cable terminal to hit the battery carrier frame! Like you concerned about....agree with your concern too
Thanks, Dan. I incorrectly assumed that the upper hold-down was metal, and not wood. You've done a great job, as always!DanTreace wrote: ↑Wed Mar 18, 2026 6:04 pmJerryJerry VanOoteghem wrote: ↑Wed Mar 18, 2026 2:35 pmI would be really concerned about the POS battery terminal coming into contact with the battery hold-down.
... the upper wood bar then is used to lock the battery in place. The Ford battery box clamps are used to secure the wood bar.
