Working on my 25 roadster
Oldrusty26
First Name: Travis
Last Name: Melnick
* REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT 25 runabout many misc projects
Board Member Since: 2012
Post by Oldrusty26 » Sun Mar 15, 2026 7:35 pm
Ok guys , finally back to working on my 25 roadster , and of coarse I have some questions , I rebuilt the rear axle and installed the bronze thrust washers etc . My question at this moment is how to the turtle decks match up with the body ? The one I have seems like it’s smaller ( narrower ) than the body . Any photos of figment would be helpful , I’ll attach pictures of what I have so far . Are the decks different for a 25 ?
Thanks in advance .
First Name: Keith
Last Name: Townsend
Re: Working on my 25 roadster
Post by KWTownsend » Sun Mar 15, 2026 7:44 pm
That looks absolutely correct.
Post by DanTreace » Sun Mar 15, 2026 9:53 pm
Your fit is going well, just align the deck to the rear tub moldings and the lower deck trim.
Then when you bolt it in place and all is good.
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Sun Mar 15, 2026 10:25 pm
That’s my issue , looks like my turtle deck is smaller than the rest of the deck of the car , is there supposed to be a ledge on the sides and rear like my pictures show ? Love that color blue on the photos you sent.
Last Name: Hatch
Post by Dan Hatch » Mon Mar 16, 2026 6:44 am
Take the deck off and get a real pickup bed. That will solve all your problems. Dan
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Mon Mar 16, 2026 7:09 am
I have a 26 roadster pick up already ,lol !!
Post by DanTreace » Mon Mar 16, 2026 9:54 am
Just may be how the wood subframe was done, if re-wooded from factory, the sheet metal pieces around the wood subframe should have separate ends, just a tiny gap. On yours looks like body filler on the ends? Could be the subframe was made a tad wider?
On my project, bought it wooded, with metal already on and painted Ford engine blue, did have to fit new primed panels on the lower side, and rear of the subframe, spent some time fitting each to the wood and squared all up. Note in one photo the old original panel (had rust holes) but used to to locate the 3 holes for the rear fender bracket forging.
Good luck, your project will turn out well too. ;)
Turtle deck bolted down on the subframe flooring.
Post by DanTreace » Mon Mar 16, 2026 10:02 am
Originals to show that the turtle deck is rather set back from the subframe sheetmetal anyway, the Ford was the Low Cost auto you know, gaps and fitment weren't priority ;)
!Bdr,Bn!B2k~$(KGrHqYOKiwEq5SGUCisBK583dfhMg~~_3 (2).jpg (127.83 KiB) Viewed 560 times
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Mon Mar 16, 2026 10:46 am
Thanks dan !!
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Tue Mar 17, 2026 9:21 pm
[image][/image]If I use 26 spindles on my 25 will it sit too low in the front or would it not be noticeable enough to matter?
Post by Scott_Conger » Tue Mar 17, 2026 10:06 pm
It will be noticeable
Now you have to wonder if you have the correct drag link and tie rod...they both came in different lengths depending on year and configuration. You may well be back here 6 months from now asking "why can't I adjust toe-in?
It's easy enough and cheap enough to buy the correct parts - that would be my choice. And it's my advice.
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Tue Mar 17, 2026 10:15 pm
Thanks !! I appreciate it
Post by Original Smith » Wed Mar 18, 2026 12:35 pm
A true 1925 uses the same front spring as a 1926, which lowers the car about 1 inch. 8 leaf compared to a earlier 7 leaf.
Post by Jerry VanOoteghem » Wed Mar 18, 2026 2:35 pm
I would be really concerned about the POS battery terminal coming into contact with the battery hold-down.
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Wed Mar 18, 2026 3:51 pm
That’s not my battery photo, I do have the correct springs installed . I have different spindles etc , so no issues to change them out , was just questioning the spindle height difference in the stance .
Post by DanTreace » Wed Mar 18, 2026 6:04 pm
Jerry
That is my photo of a '24 I did and later sold. Always have used Optima 6v batteries and make a holder to secure these oblong cases.
The lower holder is a 3/4" thick board with notches to lock into the straps of the Ford battery carrier. Then wood side braces are screwed and wood glued to the base board..... being added to prevent the oblong battery from moving, the upper wood bar then is used to lock the battery in place. The Ford battery box clamps are used to secure the wood bar.
When locked in place the battery won't move.
I learned my lesson as a teen, put a 6 volt battery in the frame and didn't secure it, figured that dang heavy battery would stay put......well it walked just enough to allow the + cable terminal to hit the battery carrier frame! Like you concerned about....agree with your concern too :o , but I have always since then secured a battery in that Ford frame. ;)
Post by Jerry VanOoteghem » Thu Mar 19, 2026 6:25 am
Jerry
... the upper wood bar then is used to lock the battery in place. The Ford battery box clamps are used to secure the wood bar.
Thanks, Dan. I incorrectly assumed that the upper hold-down was metal, and not wood. You've done a great job, as always! :)
