Reverse snapping
Jfmarkham
Topic author - Posts: 43
- Last Name: Markham
- * REQUIRED* Type and Year of Model Ts owned: 1923 pie wagon
Reverse snapping
My 1923 has started to occasionally make a snapping sound when its under a heavy load,it does it when backing up a incline or on soft ground. The noise is coming from transmission not rear end,any ideas where to start? Both forward gears work fine
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
- Board Member Since: 2024
Re: Reverse snapping
One possibility, rear end problems can 'transmit' the sound to the tranny.
Mine had the same issue, banging in reverse, but not forward, (backing out of my shop rolls into sand), sounding like it was thumping under my feet.
In my case the driveshaft roller bearing (among other things such as thrust washers) was shot causing the pinion to pop out of mesh with the ring in reverse. It acted fine going forward.
Kurt is right
nearly certain it's either pinion roller bearing failure or differential thrust washer failure
stop driving the car NOW. The ring/pinion are undoubtedly being damaged and the longer it's driven the worse the damage will get (including loss of brakes and further related damage).
You might want to block up the rear end and run the car in high at about 15 MPH for ten minutes or so, then shut it off and pull a sample of the rear axle lube. A suction gun works well for this. You will probably find excess metal debris in the lube. Rotating the wheels by hand, and running it in low and reverse while the vehicle is warmed up and on the blocks may reveal more evidence of what may be wrong. Whatever it is, it won't fix itself.
Mike Silbert
- First Name: Mike
- Last Name: Silbert
If you stick your finger in the rear axle hole it should come out smooth and slippery and not silvery and chunky.
Silver and chunky rear axle lube says - thrust washer failure.
These tests are easier and clearer when someone else is helping and listening and feeling for the issue while one is turning and wiggling parts.
To check the drivetrain, chock the front wheels, put the transmission in high and release the e-brake.
Then put the rear axle on jack stands and start checking things.
Grab the tires and lift (or pry) up and down, front to back, and in and out. It should have have no slop or sounds on these tests.
Rotate the tires each direction and there should be little to no slop and certainly no noises.
It will turn some before the the tire starts moving on the other side, more than a modern car does, but not really far.
If the slop is a lot then that is starting to point to where the issue is.
What is happening is it is rotating until the slop is taken up all the way to the crankshaft and then the tire on the opposite side will start to turn.
Next turn the starting crank and see how the drivetrain feels.
If you remove the spark plugs the engine becomes easier and smoother to rotate.
It should rotate nice and smooth without a lot of slop or strange noises.
To go further, shift the transmission through the gears and see what happens and how it feels and sounds.
I have seen all kinds of issues that could possibly be close to what you describe ranging from transmission cracks, bushing issues, loose rivets, u-joint issues, pinion issues, thrust bushing issues and more.
The trick is to narrow it down to an area and and possible cause.
Mike
Mike
Dennis_Brown
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Have you tried jacking up one rear wheel, releasing the emergency brake leaving the handle in the neutral position ,thereby taking any pressure off the differential and removing the plug at the rear if the u-joint and see if you can move the drive shaft back and forth. This should show if your drive shaft and pinion are moving out of mesh with the ring gear. This might help eliminate your problem there. Only a suggestion, good luck.
Jfmarkham
Im not familiar with a plug by the universal by the transmission, should I be looking for movement from front to back or play in left and right on the shaft
That sounds like the pinion gear slipping over the ring gear.
Thats typically a disintegrated DS bearing & race.
The sound migrates up, like its right under the transmission inspection cover.
There are 2 plugs to access the u-j. pin - they're right behind or in front of the grease cup for the front d.s. bushing.
Jfmarkham
speedytinc wrote: ↑Sat Mar 21, 2026 4:04 pmThat sounds like the pinion gear slipping over the ring gear.
So is it possible its just the worn bearing and race causing so much play that makes it jump or do you think the ring and pinion are bad?
In my case, the gears were not damaged enough to replace. They were marked some. Got lucky there.
However the drive shaft, race, bearing & outer spool were not usable. The inner race shattered like glass & destroyed the bearing.
The chunks of inner race didn't get caught in the gear teeth, but settled to the bottom of the differential housing.
Jfmarkham
Thank you, I live in upstate NY so we still have it stored away,waiting for snow to leave, I will tear it apart hopefully in the next month, Im not sure this project is in my ability range but got to at least give it a try, will keep you in the loopspeedytinc wrote: ↑Mon Mar 23, 2026 6:28 pmIn my case, the gears were not damaged enough to replace. They were marked some. Got lucky there.
Try a magnetic pick up tool or a magnet on a wire to drag the bottom of the diff for chunks to confirm.
Also a scope thru the fill hole to examine gear teeth.
You want as much info as possible before tearing down.
Jfmarkham
I just jacked it up, no play left or right or in and out on the wheel, I pulled the bottom U joint plug tried to move shaft but screw driver just slips if I hold the drive shaft with screw driver and slowly move the wheel back and forth i do get some free play but don't know how much is normal, I can move the wheel in free play about the distance between two spokes, so if the spoke is at 12 o'clock I can turn it about to 1 o'clock before I hit resistance,make any senseDennis_Brown wrote: ↑Fri Mar 20, 2026 4:56 pmHave you tried jacking up one rear wheel, releasing the emergency brake leaving the handle in the neutral position ,thereby taking any pressure off the differential and removing the plug at the rear if the u-joint and see if you can move the drive shaft back and forth. This should show if your drive shaft and pinion are moving out of mesh with the ring gear. This might help eliminate your problem there. Only a suggestion, good luck.
Jfmarkham
Jfmarkham
I just jacked it up, no play left or right or in and out on the wheel, I pulled the bottom U joint plug tried to move shaft but screw driver just slips if I hold the drive shaft with screw driver and slowly move the wheel back and forth i do get some free play but don't know how much is normal, I can move the wheel in free play about the distance between two spokes, so if the spoke is at 12 o'clock I can turn it about to 1 o'clock before I hit resistance,make any sensespeedytinc wrote: ↑Tue Mar 24, 2026 8:08 amTry a magnetic pick up tool or a magnet on a wire to drag the bottom of the diff for chunks to confirm.
While looking through that u-joint plug hole, and with the transmission in high gear, have someone rotate one of the rear wheels back & forth. You're looking for excessive rotation of the driveshaft/u-joint when doing this. The thought being that maybe your u-joint is the source of trouble.
Jfmarkham
If it were the U joint wouldn't it do it in both forward and reverse? I only hear it in reverseJerry VanOoteghem wrote: ↑Wed Mar 25, 2026 11:13 amWhile looking through that u-joint plug hole, and with the transmission in high gear, have someone rotate one of the rear wheels back & forth. You're looking for excessive rotation of the driveshaft/u-joint when doing this. The thought being that maybe your u-joint is the source of trouble.
Not necessarily. Either way, it's an easy thing to check and it removes a variable from the diagnosis.Jfmarkham wrote: ↑Wed Mar 25, 2026 11:31 amIf it were the U joint wouldn't it do it in both forward and reverse? I only hear it in reverseJerry VanOoteghem wrote: ↑Wed Mar 25, 2026 11:13 amWhile looking through that u-joint plug hole, and with the transmission in high gear, have someone rotate one of the rear wheels back & forth. You're looking for excessive rotation of the driveshaft/u-joint when doing this. The thought being that maybe your u-joint is the source of trouble.
