Renning Headlight wires
Jed
Topic author - Posts: 28
- First Name: Jed
- Last Name: Welsh
- * REQUIRED* Type and Year of Model Ts owned: 1920 Roadster pick-up
How do I run the headlight wiring through the body to the headlight on a 1920 roadster? Without the Hood landing on It.
Re: Renning Headlight wires
Run under the hood shelf.
Later shelf with notch Earlier ones with grommet
On our Canadian sourced cars, the hole in the top of the hood shelf, with the hard rubber grommet, is the last incarnation. Earlier cars had the notch in the side.
