Engine Mounting Bolts
Last Name: Juhl
Post by Oldav8tor » Tue Jul 16, 2019 9:38 am
It's clear from what I've read that the bolts that go horizontally thru the frame and wood block are not to be tightened beyond the point where they don't rattle but what about the top bolts? Same thing? Snug? Tight? I've been researching but the answer isn't clear. Thanks!
Re: Engine Mounting Bolts
Post by DanTreace » Tue Jul 16, 2019 10:06 am
Tim
The frame top rail to pan bracket short bolts are tight! No wiggle, drawn down tight and insert cotter in the castle nut on top.
The top ones are fastened first, before you place the wood blocks into the frame rail.
The longer side bolts, placed into the wood blocks, are drawn up snug, not loose, but don't pull them so tight as the top ones. Like to finger tight, then wrench only enough to align the cotters for inserting. With the snug, you should be able to turn the head of the long bolt against the frame rail, and the castle nut with cotter should gently twist with it.
Last Name: Juhl
Post by Oldav8tor » Tue Jul 16, 2019 2:21 pm
Thanks Dan :-)
As someone who taught high school science for 34 years, I got used to answering the same questions over and over. It requires patience and a smile..... I appreciate your patience and that of other forum members when the same questions keep coming up. Please know that we newbies appreciate it!
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Tue Jul 16, 2019 3:04 pm
I'm about to install an accessory engine support (aka belly-band) that came with a parts chassis.
It's secured to the frame via the horizontal bolts. Do the same procedures about tightening apply with the belly-band added?
1924 Touring
Post by DanTreace » Tue Jul 16, 2019 4:42 pm
Tim
You are welcome, that little detail is also noted in Ford Service, paragraph 100.
The belly bands are just added support for the engine crankcase already mounted. So yes, install the T engine factory way, wood block motor mount at pan, with both bolts, and be sure the wood block inside the frame to the inside of pan arm is tight, you want to have to knock that block in place.
Takes strain off the arm, as the whole engine will twist in the chassis with braking and low pedal acceleration.
Note the marks of the arm on the inside of an original wood block, was fitted very snug to get this impression.
Have those belly bands also, can't hurt and may help keep me out of the 2-piece crank club 8-)
IMG_0718 (800x600) (580x435) (579x434).jpg (142.75 KiB) Viewed 4944 times
IMG_0369 (579x600).jpg (169.92 KiB) Viewed 4944 times
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Wed Jul 17, 2019 7:05 am
This newbie sure appreciates the info! I will be pulling and replacing my engine this Fall, and I had no idea about the different tightening specs. I guess I should read the instructions...
Maybe the guys who have been at this for a while and know these details could put together a book called something like "The Fine Points". I would buy it!
Cheers, Bill
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Wed Jul 17, 2019 10:11 am
Dan-
If the top bolts are taken up tight before installing the wood blocks why is the top of the block cut to hold the bolt head while tightening?
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Wed Jul 17, 2019 10:21 am
Not sure but I thought that was for a space to run wiring.
MWalker
Last Name: Walker
Post by MWalker » Wed Jul 17, 2019 10:40 am
The top of the wood block is notched so it will clear the bolt head when you insert the block. The bevel at the bottom of the block creates a space where the gas line runs.
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Jul 17, 2019 10:51 am
As belly bands were brought up, I think it’s a good idea to apply a thin rubber surface between the pan and band. The ones we manufacture have a thin neoprene pad glued on.
