Improved car front axle
John Codman
Last Name: Codman
Post by John Codman » Wed Jul 17, 2019 12:36 pm
Can someone post a clear photo of an "improved car" front axle? In the parts section a poster commented that all of the '26 and '27 Model Ts had a dip in the center of the axle. I have no reason to believe that the axle in my '27 has ever been swapped, but it doesn't appear to have a dip in it. I'm wondering if I'm not seeing something that others do.
Scottio
Re: Improved car front axle
Post by Scottio » Wed Jul 17, 2019 1:16 pm
I just walked out and looked at my 26 Roadster and I don’t see any discernible dip. I can never get pictures to work on this site so I can’t post one but mine is straight across.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Jul 17, 2019 1:31 pm
My '26 has a very slight sway to the upper surface. Would that make it from an older car or is there a 1/2" overall dip? I need to measure it. This is from the encyclopedia.
In Sept. 1920 Ford introduced a new design axle forging which was straight between the two spring perch bosses. The older design is curved between the two bosses. The older curved design was designated T-202-B1 and was made by Herbrand. Transue & Williams and Ford made the straight design which was designated T-202-B2. (The curved design referred to here is not the same as the late 1926 and 1927 where the middle of the top of the axle is about 1/2” lower, and presents a definite distinguishable curve between the perches, than on older designs.)
My car:
Post by DanTreace » Wed Jul 17, 2019 3:11 pm
Swoop front axle 1927 (500x445).jpg (97.25 KiB) Viewed 6668 times
The 1927 model year front axle has the swoop, eng. change August 1926.
Comments in Bruce's C-D Encyl.:
8-2-26 “Specified I section at center to be lowered .5” and upper part of I section to have a 1” true sweep instead of being straight in center.” (This refers to the 1927 front axle. It is easily distinguished by the “droop” in the axle between the spring perches. Number 15,000,000 has this axle.)
Derek Kiefer
First Name: Derek
Last Name: Kiefer
* REQUIRED* Type and Year of Model Ts owned: 1925 Touring, 1926 Gow Job
Board Member Since: 2011
Post by Derek Kiefer » Wed Jul 17, 2019 3:51 pm
I have several axles with 26-27 spindles and none of them had the dip.
I had a 27 roadster, which DID have the dip in the axle.
TeveS-Nor Cal
Last Name: Straw
Post by TeveS-Nor Cal » Wed Jul 17, 2019 5:55 pm
Why a "DIP"?
John Codman
Last Name: Codman
Post by John Codman » Tue Jul 23, 2019 1:59 pm
My axle definitely does not look like the '27 in the photo.
ChrisB
First Name: Chris
Last Name: Brancaccio
Post by ChrisB » Wed Jul 24, 2019 3:44 pm
When they lowered the spindle did they not also flatten the spring?
If so the curve could be extra clearance when the axle moves up & down.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Post by DanTreace » Wed Jul 24, 2019 3:51 pm
Yes.
The Improved Car (26-27) has lower ached front spring, came along with the lowered spindles.
p/n 3800B 8 leaf front. '26-'27, and all the individual leaves are different from the '25 and earlier front spring.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Wed Jul 24, 2019 4:44 pm
Here photos of a fresh restored 1926 front axle.
Andre
Belgium
Hap_Tucker
First Name: Hap
Last Name: Tucker
Post by Hap_Tucker » Wed Jul 24, 2019 8:19 pm
Andre,
Your axle appears to be the English Ford produced axle that they introduced with the Drop Ford cars in Jan 1924 (ref page 230 of the English Ford Book vol 1). Below is an illustration from one of the English Ford Price List of Parts showing the earlier style regular front axle and the DF or Drop Frame front axle that they produced in England.
Hap_Tucker
First Name: Hap
Last Name: Tucker
Post by Hap_Tucker » Wed Jul 24, 2019 8:34 pm
Andre.... continued:
For a 1926-27 car assembled in Denmark, England etc. -- they used the DR front axle and DF wishbone but the standard style USA type front spindles. Ref: http://www.mtfca.com/discus/messages/331880/375948.html Also ref page 180 of the English Ford Book vol 1.
Respectfully submitted,
Hap l9l5 cut off
