Metal channel for the top window rubber on a 1927 coupe door
Topic author - Posts: 57
- First Name: Joe
- Last Name: Gallagher
I am looking for the metal channel for the top window rubber for a 1927 Coupe door... this is attached with 3 screws to the inside top of the door frame...I do not think it is made any more ??? Thanks for any help ... Joe ... joeg48@hotmail.com
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Re: Metal channel for the top window rubber on a 1927 coupe door
Are both missing?
- First Name: Joe
Richard .... Yes both are missing .... Joe
- First Name: Ted
- Last Name: Dumas
- * REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
You could make a channel by using two smal thin aluminum angles.
