Spindle differences
70shovelhead
Topic author - Posts: 85
- First Name: Preston
- Last Name: Wells
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
- Board Member Since: 2008
Spindle differences
Need to replace both spindles on the front of my 26 TT. Project. There are several choices of individual spindles and a couple of pairs on ebay, all 1920 and later. Will these work to replace mine? I am assuming the TT front end is the same as the car.
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
Re: Spidle differances
all 1926-7 spindles will work but all pre 1925 are not offset like you need, the 26-7 spindles are offset, Bob we have them here all rebuilt
815-633-7244
815-633-7244
- Last Name: House
WOW !!.. $75-$85 for a used pair of spindles on eBay!! Bobs right ‘18-‘25 spindles is what you need. The ‘26-‘27 CARS used spindles that dropped the front end 1/2” - but not the Ton Trucks. I can send you a pair for less than half the eBay prices + shipping.
70shovelhead
- Last Name: Wells
Sent you an email George.
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
70shovelhead
- Last Name: Wells
Re: Spindle differences
So I ran across a couple of left side spindles a friend gave me. The problem is I need to replace the right spindle due to worn out threads. My question is this. With regard to the geometry only(not concerned with casting numbers or machining for the tie rod arm) will a left spindle work on the right side. I did a retro fit today and I see (with the naked eye) no difference. Attached the tie rod and all moved as it should with no binding. What do the experts say? Will caster or camber be effected?
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
Spindles are right hand & left hand thread and MUST be installed so the threaded outer wheel bearing "loosens" when traveling in a forward direction - don't mix them up !!!
- Last Name: House
Received no emails Preston. I don’t know how to find PMs. Try gwhouse731@gmail.com if you’re still in need. I’d send a pic of what I’d mail you...george
70shovelhead
- Last Name: Wells
Thanks for the replys George and RojaRacer. I had forgot about thread direction. I did have T Haven find a passenger side spindle, bearing and nut. Seems that this TT trucks rt spindle was replaced years ago with a 26-27 left side spindle(notice right hand threads). This explains why the threads are wore down.
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
