Improved car headlight bar bolts
Topic author - Posts: 1532
- Last Name: Codman
I need to replace one incorrect headlight bar bolt on my '27 with the correct carriage bolt. The issue is that I don't know whether the nuts are supposed to be square or hex. The three original-looking carriage bolts have hex nuts, but the taillight bracket has square nuts. I would have thought Ford would have been consistent and used one or the other. Does anyone know for sure what sort of nut would have been used?
- Last Name: Zibell
Re: Improved car headlight bar bolts
Original nuts are square. That said, I did change mine over to hex. Easier to deal with.
1926 Tudor
- Last Name: Codman
Thanks! Doer anybody have four good square headlight bolts that they would like to sell to me?
- Last Name: House
John,
You need - and mean - square NUTS !!
- First Name: Tom
- Last Name: McGoldrick
- * REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
I'm not sure what size you need but http://www.blacksmithbolt.com/store/c/41-Nuts.aspx has all kinds available including in black oxide finish.
- Last Name: Menzies
- Board Member Since: 2012
My original Canadian '26 has hex nuts for the bar and the headlights. Just to mention in the day there were square socket sets to deal with square nuts. Today Snap-On tools sells square sets called
"four point" also "eight point" that will work on square nuts, but the "four point" fits better.
Maybe the Canadian models were different? I have had the car for 60 years and they were hex when I got it.
- First Name: Tom
HF sells a set of spline sockets that work well on square nuts. Inexpensive
- Last Name: Zibell
I picked up a set of 8 point sockets. Unfortunately I don't remember where I ordered them from. The were not any more expensive then the usual 6 or 12 point sockets for hex nuts. A web search should result in a source.
1926 Tudor
- First Name: Henry
- Last Name: Lee
John when you find the size required, I believe they are 5/16' NC or 3/8" NC, let me know. I have plenty of NOS square head hardware on hand.
Hank in Tin-A-See
Hank in Tin-A-See
- Last Name: Codman
You don't need square or eight-point sockets for square nuts. Regular 12-point sockets work just fine. I installed a new carriage bolt and square nuts on the driver's side today with a 12-point socket. I was amazed that my local Ace Hardware store stocks square nuts!
