Babbitt Material
keen25
Topic author - Posts: 108
- First Name: Eric
- Last Name: Keenan
- * REQUIRED* Type and Year of Model Ts owned: 1923 coupe, 1925 TT, 1926 coupe, 1925 Tudor, 1925 pickup, 1926 fordor
Babbitt Material
Where is the best place to buy Babbitt material? Who has the formula that is the best grade or one that is the same composition as the Ford model T? Thank you. Erick
Erik Barrett
- First Name: Erik
- Last Name: Barrett
Re: Babbitt Material
I buy government grade #2 from United Metals. They publish their formulae online and it is what Ford used for model T’s.
Kerry
- Last Name: van Ekeren
If your only doing 1 engine then buy the babbitt from the T vendors. I don't know about your area but down my way if you want babbitt from a metal merchant supplier you can only buy in bulk, which is fine if doing several engines.
Kohnke Rebabbitting
- First Name: Herman
- Last Name: Kohnke
- * REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Not the same as Fords, Erik.Erik Barrett wrote: ↑Tue Aug 06, 2019 7:57 pmI buy government grade #2 from United Metals. They publish their formulae online and it is what Ford used for model T’s.
Herm.
- Last Name: Hatch
Here a place that makes Ford babbitt. http://stores.acrosales.com/fordbabbitt/
Dan
Dan
modernbeat
- First Name: Jason
- Last Name: McDaniel
- * REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
While there is debate about what is the "best" Babbitt, there are a number of similar materials to what Ford specified.
You can buy smaller quantities here:
https://www.kappalloy.com/babbitt-alloy ... urakapp-2/
https://www.kappalloy.com/kappatinningt ... -1-lb-jar/
Jason McDaniel
Erik Barrett
- First Name: Erik
Herm, please elaborate. I’d like to learn more.
Kohnke Rebabbitting
- Last Name: Kohnke
I will try to do it tonight, Mr. Erik, I am pouring in a 1903 Olds, today.
Herm.
Dropacent
- Last Name: Morsher
Here it is ! [attachment=0]
Kohnke Rebabbitting
- Last Name: Kohnke
Just because babbitt has Ford in the babbitt, does not mean it came from the Ford Factory, it may be 86-7-7, but it didn't come from Ford.
The babbitt in the Ford Garages, that we got with Wilson tools, that was Ford Babbitt, all had Ford Imprinted in the bar, and written out, Just like the Model T, and A, signs.
We have had a lot of Babbitt that was Printed Ford in it, but was lead Babbitt. Henrys, Gyp parts.
Most all Bearing Manufacturers, used Grade No. 11, specified by car builders.
We use Grade No. 11, and also a lot of Grade No. 2.
We don't use much of 86-7-7, Ford formula, as it machines dirty.
Herm.
Herm.
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
Just in case anyone in Australia stumbles across this thread, I use Consolidated Alloys "Auto" white metal.
http://www.cagroup.com.au/wp-content/up ... s-2017.pdf
You can buy it direct from them or order it through a reseller like Blackwoods or Bunnings Trade.
Dropacent
BUT IT SAYS “GENUINE “. Thought I’d go fishing with that pic and I caught a big one !
Erik Barrett
- First Name: Erik
Herm, thanks for the input. I will stick with grade 2. My book on rebuilding model A’s claims that Ford went to a cheaper lead base babbit because they thought the more robust, larger crankshaft did not require the more expensive grade. Maybe that is why the Ford name is on some lower grade babbit ingots? Just a thought. Is your Oldsmobile project a curved dash one cylinder? Always an admirer of your work and formidable experience. The oldest thing I have done bearing work on is a 1904 B Ford.
BuddyTheRoadster
- First Name: Chris
- Last Name: Rini
- * REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Herm, how do you chose when you use Grade No. 11 and when you use Grade No. 2 Babbitt?
Kohnke Rebabbitting
- Last Name: Kohnke
Grade 2 is fine, we use it some times. Buddy, it all depends on price, and availability.Erik Barrett wrote: ↑Thu Aug 08, 2019 1:19 amHerm, thanks for the input. I will stick with grade 2. My book on rebuilding model A’s claims that Ford went to a cheaper lead base babbit because they thought the more robust, larger crankshaft did not require the more expensive grade. Maybe that is why the Ford name is on some lower grade babbit ingots? Just a thought. Is your Oldsmobile project a curved dash one cylinder? Always an admirer of your work and formidable experience. The oldest thing I have done bearing work on is a 1904 B Ford.
Yes, that was in, I think early V-8's. The Early Ford V-8 Forum would know.
Yes, Ford tried Lead, a Copper Lead, it didn't work out, so they went to a Cadmium Sliver alloy.
The V-8 Ford Ron Bearings were never repoured, as they wear on out side, and in.
The olds is a Curved Dash, 1903. we have don a Shott " SP " A Yale, and I can't think of the other.
Herm.
