Painting ther Engine
bill goodheart
First Name: William
Last Name: Goodheart
Post by bill goodheart » Tue Aug 06, 2019 12:35 pm
I am about ready to paint the engine for my 1919 non starter touring. Is the cylinder head supposed to be the same color as the block? I am using satin black for the block. I intend to paint the exhaust manifold with Eastwood Manifold grey.
Mark Osterman
Last Name: Osterman
Re: Painting ther Engine
Post by Mark Osterman » Tue Aug 06, 2019 12:47 pm
I think the authentic color scheme is slightly oily black with rusty red accents.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Tue Aug 06, 2019 1:14 pm
Satin black for all engine parts would be a good choice.
Post by Steve Jelf » Tue Aug 06, 2019 1:40 pm
There is a persistent superstition that Model T engines were never painted. This picture of the 1917 Rip Van Winkle car disagrees.
I agree that satin black is a good choice. I use the Rustoleum version.
AdminJeff
Post by AdminJeff » Sat Aug 10, 2019 1:12 pm
I did quite a bit of research on this when I had my engine out of the car recently. In the interest of saving time, I painted everything in one go. I ended up using this product.
https://www.amazon.com/POR-15-45918-Cha ... th=1&psc=1
This stuff is amazing. It is hard as nails once it dries. And it still looks great after several months of use. The trick is to get everything clean, clean, clean. Wire brush, degreaser and carb cleaner. Repeat.
I got 2 medium coats on the engine and a few extra parts with one can. The final results were amazing. Just be careful with this paint. Once it gets on something, it’s next to impossible to get it off.
Jeff
Post by TRDxB2 » Sat Aug 10, 2019 2:27 pm
I am not knocking the product POR-15 Top Coat. In fact I plan to use it. BUT since we don't always read directions I thought I make sure you all see this caution for the product "DANGER: RAGS, STEEL WOOL OR WASTE SOAKED WITH POR-15 TOP COAT MAY SPONTANEOUSLY CATCH FIRE IF IMPROPERLY DISCARDED. IMMEDIATELY AFTER USE, PLACE RAGS, STEEL WOOL, OR WASTE IN A SEALED WATER-FILLED METAL CONTAINER."
Instructions on use
https://por15.com/assets/images/techdat ... CoatLR.pdf
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sat Aug 10, 2019 3:13 pm
I use Rustoleum Black Rust-reformer for most of my parts. Spray .. let dry for a few minutes and then rub with a cloth for an aged paint luster. I use the red cotton rags sold at the auto parts stores.
AdminJeff
Post by AdminJeff » Sat Aug 10, 2019 4:01 pm
Instructions on use
I used to think this was some corner case that caused this mandated wording on some labels but
Not any more. A couple yrs ago a can of stain soaked rags spontaneously ignited and caused a pretty large garbage pile fire on my property, fire engines and all. The fire chief and I traced the definitive ignition source to the can of used stain soaked rags. I had another unused can of the stain, and sure enough, that warning was on the can. Ever since then I read the warning labels and put used rags in water and seal the containers.
Jeff
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Sat Aug 10, 2019 5:21 pm
After cleaning 2 coats of the wrong green off of a '26 engine I got down to the back "wash" coat that's discussed a number of times here on the Forum. I stood with that.
jab35
Last Name: Bartsch
Post by jab35 » Sun Aug 11, 2019 10:37 am
Charlie: You refer to 'the wrong green stuff' painted on your '26 engine. What color green was that paint? I see a lot of ugly painted Model T engines at car shows that clearly aren't correct, so I'm interested is what color Ford used in '26-'27. (And ugly to me doesn't mean the owners did wrong by their cars, I respect their choices)
Bruce refers to 'Moleskin' paint for engines in the improved Fords? You weren't referring to Moleskin as the wrong paint, were you? I have yet to paint my engine for a '26 coupe, and hope to do it once in the 'original' color. And is the moleskin engine paint different from the engine paint used on the first Model A's? Thanks for any info, jb
John Codman
Last Name: Codman
Post by John Codman » Sun Aug 11, 2019 11:50 am
There has been considerable discussion about the proper engine paint color on this forum. As I recall, nobody has found a documented original engine that was stored well-enough that the exact color can be determined. In a lengthy thread a while back, the consensus was that "moleskin" was the correct color, but we don't know exactly what color that is. I had the head off of my T and painted it high-temperature rattle can black while it was off. In the absence of certainty of the actual original color, I'd vote for black.
Post by Steve Jelf » Sun Aug 11, 2019 1:11 pm
I'd say the Rip Van Winkle engine shown above is a pretty good clue. I'm sure it has never been repainted.
This assembly line photo (1924 if I remember correctly) is another good clue. You can clearly see the "Gilsonite wash" and a place that it missed on the valve cover.
For26-27 I would go by this example at The Henry Ford. In the MTFCI judging/restoration guidelines the color is called "Drake green". It looks very close to military OD to me.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sun Aug 11, 2019 1:14 pm
My dad has been in the hobby since 1948. There were many Ford dealers that had NOS Model T parts back then.
In the late 1940s or early 1950s, my dad acquired an NOS 1927 head from a Ford dealer. The head did not have a Ford script or "made in U.S.A" and had its original green paint and factory paper tag.
My father sold the head about 25 years ago. Unfortunately, we never took photos of it.
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Post by Steve Hughes » Sun Aug 11, 2019 1:20 pm
I guess one way to know for sure what color that would be is to catch a mole, skin it, and see what color it is. :lol:
Post by Original Smith » Sun Aug 11, 2019 8:15 pm
You can't go by the Rip Van Winkle, because a former owner took the whole car apart, and put if back together.
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Sun Aug 11, 2019 8:59 pm
Is there any document evidence that Model T engines were "painted" with Gilsonite ?
I have read that the black cars were dipped in Gilsonite as body paint. This would explain
why period photos show the paint lost its shine quickly, if exposed to the elements.
Gilsonite is a "varnish"-like material, like a thinning tar that hardens like paint. But it
IS a tar kind of material and weathers much the same. If anyone has access to a known
original engine, looking in the nooks and crannies of the castings might show thicker buildups
still holding on, looking like dried grease. In fact, it may prove quite the challenge to tell
the two apart.
Gilsonite was a popular "paint" for many utilitarian metal objects during the steam era.
I have a number of Victorian period items that still wear their original Gilsonite paint.
Post by Steve Jelf » Mon Aug 12, 2019 1:26 am
,,,a former owner took the whole car apart, and put if back together.
Why? Did he give any reason?
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Mon Aug 12, 2019 4:47 am
That's just nuts!!!!! Why would ANYBODY do that to such of an almost non existent original car? I am beyond amazed!!!!! And saddened as much. :shock: :shock: :shock: :shock: What were they thinking??? I can't and probably will never understand that. What a waste. :shock: :shock: :shock: Dave
1925 mostly original coupe.
Bill Everett
First Name: Bill
Last Name: Everett
Post by Bill Everett » Mon Aug 12, 2019 12:48 pm
Jeff, sent you an e-mail.
