TT rear hubs
Rod Petrie
Topic author - Posts: 88
- First Name: Rod
- Last Name: Petrie
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
TT rear hubs
The threads on my 26TT rear hubs are pretty boogered up. Is there a tool or a way to fix them or do I just go without hub caps? I bought a hub puller before I got the truck home in anticipation of needing it to pull the rear wheels. The wheels came right off so didn't need it. It is a good thing because it wouldn't screw on far enough to do any good.
- Last Name: House
Re: TT rear hubs
About the only advice I can offer is obtaining one of those about 9” x 3/4” square metal thread chasing tools. There’s 8 different TPI selections on each tool. Someone will chime in with the specific TPI for TT rear hubs. I’m not familiar with a thread chaser like the one available for T hubs. Otherwise, find another TT rear hub with good threads. They’re not rare. I have several...
PDGx
- First Name: Paul
- Last Name: Grohsmeyer
Re: TT rear hubs
The rear hubs are 16 TPI.
Yes, and if you don’t already have a set of these -
- you ought to get a set.
They can clean up about any external thread from about 8-32 TPI. They work like a file using any remaining thread grooves for alignment. Just work your way around the hub til you get it cleaned up.
I believe amazon even has them now.
