Need a source for the spring inside the door of a Center Door sedan.
I cannot seem to match the correct length to wire thickness and spring diameter.
Spring Source
Will_Vanderburg
Topic author - Posts: 948
- First Name: William
- Last Name: Vanderburg
Spring Source
William L Vanderburg
1922 Center Door Sedan
Will_Vanderburg
Re: Spring Source
Mine are approximately 8 inches in length total with elongated hooks, 0.11 inch wire diameter and 0.69 spring diameter
Re: Spring Source
