What the heck is this?
Mark Osterman
Topic author - Posts: 1014
- Last Name: Osterman
Am disassembling a hand crank coil tester and found this in a stamped brass box screwed to the base. Any ideas?
Ruxstel24
- Last Name: Hanlon
Re: What the heck is this?
I'd be inclined to maybe call it a resistor ??
Dropacent
- Last Name: Morsher
Bay Bridge Sue got mine a month or so back, and asked the same question. Should be easy to find that thread, Mark.
It’s a choke coil to put load on the magneto.
http://www.mtfca.com/discus/messages/29 ... 1188667342
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
That is an Inductor.
As Dan said, it is used to simulate the load of an ignition coil when the car magneto is connected to the HCCT for testing.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Mark Osterman
Hey Dan, Thanks! That’s right on the money. Very interesting. Looks like I wouldn't need to reinstall this if I don’t plan on using this machine to actually test the magneto in the car. I sent a message to Ron asking about this the same tome I posted it here. Should get a confirmation soon enough.
BE_ZERO_BE
- First Name: BOB
ALso, that's the second one I've seen of that style in that condition.
Be_Zero_Be
Be_Zero_Be
Mark Osterman
Is it in good condition or bad condition? LOL .. I wouldn’t know. Seems to be surrounded by a shield made of stiff wires. Do I need to reinstall?
BE_ZERO_BE
- First Name: BOB
The inductor is only in play if you want to test the output of a car magneto.
It is not used for the normal testing of ignition coils.
Be_Zero_Be
Be_Zero_Be
