Atwater Kent distributor installation
Topic author - Posts: 5
- First Name: David
- Last Name: White
- * REQUIRED* Type and Year of Model Ts owned: 1914
I purchased an Atwater Kent model LA distributor. It’s in excellent condition but
1- I need the condenser
2- missing the spacer and washer
3-any advise on proper installation, timing and setup
Any help that you can give me would be greatly appreciated. The photo attached is not mine but a similar one for reference
Thank you in advance, David
- First Name: Henry
- Last Name: Lee
Re: Atwater Kent distributor installation
Dave tomorrow will dig out my original manuals, scan and post!
All the Best,
All the Best,
- First Name: Henry
- Last Name: Lee
I just looked and do not have it for that model. A VW 009 distributor condensor works great or one for a Mallory dual point.
Did a search on he Old Forum found one thread that has several members discussing instructions so one of them has what you need. The PDF file is now blank, otherwise it would have been the ticket http://www.mtfca.com/discus/messages/33 ... 1383587387
If the spacer is the same as for a American Bosch 600 distributor - 1/2 in in length and slides over end of the cam.... I have some (price of the stamp)
I think he must have found one of the links shown in that posting, I think the screen shot is mine.
http://www.mtfca.com/discus/messages/29 ... 1170023863
- First Name: David
- Last Name: White
Mark gregosh, yes it is from your post. I looked back in the archives and still looking for help. Thank you
The Ford Owner has the instructions
or;
https://www.modeltford.com/item/AK2.aspx
The material in the "The Ford Owner" has a 1999 Copyright so am not going to copy it.
You will have to make your own rod that goes from the distributor to steering column, it has different shape and is longer then stock rod.
or;
- Last Name: Goertzen
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1927 Runabout
Here are four pictures of my original instruction sheet.
The first two pictures are of the first side. The third and fourth picture is of the other side. Hope this helps.
Holler if you need better pictures.
Upon further examination it appears my instruction sheet is a reprint that is currently available from Lang's. Since I don't want to violate any copyright laws or cause harm to Lang's, I wish my post could be deleted.
