Wire spool source
Dellpound
Topic author - Posts: 37
- First Name: Dell
- Last Name: Pound
- * REQUIRED* Type and Year of Model Ts owned: Looking
Wire spool source
Does anyone know a good source for small spools of cloth covered automotive wire? I prefer to buy spools instead of set lengths.
Re: Wire spool source
By the spool: https://vintagewireandsupply.com/round- ... ered-wire/
by the foot: https://www.modeltford.com/pl.aspx?t=s& ... ire&page=1
jsaylor
- Last Name: Saylor
Check out Sacramento Vintage Ford. They sell vintage cloth covered wire.
https://www.vintageford.com/sect_vehicl ... ing%20Shop
916-853-2244
916-853-2244
I bought 6 different colour spools from these folk; www.ynzyesterdaysparts.com.
Y n Z's yesterdays parts in Redlands, California. It's on Stewart Street. They will also make you an authentic custom loom from your original pattern. Gene, the owner, even wove the original Ford script tag into my looms for my 1925.
Just be sure you get a heavy enough gauge wire! Six volt systems should not use 14 gauge. twelve gauge or even ten sometimes.
Sparknwire
- First Name: RJ
- Last Name: Lucyszyn
- * REQUIRED* Type and Year of Model Ts owned: 1913 Speedster
14 ga is mainly used on the harness generators 10-12ga
Dellpound
- First Name: Dell
- Last Name: Pound
I thank those who responded. My supplies are on there way from numerous suppliers.
GalebG2
- First Name: Oliver
- Last Name: Vandebroucke
Thanks for the links, I'm not looking for wire spool for a Ford T, but I've found LOTS of other things I need on these shops...
