Replacing Watford with stock drive line.
70shovelhead
Topic author - Posts: 85
- First Name: Preston
- Last Name: Wells
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
- Board Member Since: 2008
I'm looking at replacing the 3 speed Watford and using a stock drive shaft and tube on my 26 TT project. Is there any other considerations I need to look for beside a drive shaft and tube. I'm looking so if anyone has a set Id be interested. Thanks
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
HPetrino
- First Name: Henry
- Last Name: Petrino
Re: Replacing Watford with stock drive line.
Typically you'll also need a pair of full length radius rods too.
If I may ask - Why are you removing it?
- Last Name: House
I know I have a TT torque tube - maybe a driveshaft as well. Also have a friend from Destin FL coming to see me next week....in a F250. Couple
70shovelhead
- Last Name: Wells
Hpetrino Im not removing it just not installing it on this rebuild. The PO indicated a problem with it shifting. I know nothing more than that.....so thinking going stock for now, then research the Warford
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
Provided the gears and etc are reasonably good, a good overdrive is the single best improvement to a model TT. It helps them to be marginally drivable outside a very limited area. Warfords and other similar transmissions ARE difficult to shift! It is a acquired skill that many people never can master. However, most people, with a bit of instruction, and a fair amount of practice can get good at it.
I would recommend putting the Warford in. Worst case, for all forward travel, put it in overdrive and leave it there. An unloaded TT can be driven that way about as well as a standard T without additional gearing.
If you are really concerned about needing to shift it? Try getting one of the "Universal" or Rocky Mountain" transmissions. They are much easier to shift.
With ANY added gearing in a model T, make SURE you have good hand or pedal brakes that won't fail if the transmission gets stuck out of gear!
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
I would not have a Model T without a Warford! Well almost and especially a TT so I've heard. After lots of miles I can tell you that a little grinding noise when trying to shift has not hurt any of the teeth. I'm really amazed at the condition of the gears. They surely are made of some good stuff!
1912 Torpedo Roadster
