HEED this WARNING!
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
HEED this WARNING!
Post by Bill Robinson » Mon Aug 26, 2019 12:42 pm
While on the MTFCA Highland Rim Tour, I personally saw 4 T's that blew head gaskets. I was told that there were actually 7 T's that lost one. One car blew 2 because he failed to re-torque the head after a warm-up.
So, the next time you walk out to your shop, grab your torque wrench and RE-Torque the head on your engine(s). Don't gamble and don't assume.
3 minutes and you'll be done. :D
First Name: Henry
Last Name: Lee
Re: HEED this WARNING!
Post by Henry K. Lee » Mon Aug 26, 2019 1:05 pm
Bill Great Reminder.
I retorque my heads multiple times!
Have never blown one.
Hank
Post by RajoRacer » Mon Aug 26, 2019 1:28 pm
I'm in Hank's "camp" - a minimum of 3 heat/cooling cycles and I've probably installed over 100 + Model T & A heads & yet to have a failure !
thom
First Name: Tommy
Last Name: Coffey
* REQUIRED* Type and Year of Model Ts owned: '21 Touring
Post by thom » Mon Aug 26, 2019 1:44 pm
I would never change a head gasket and not retorque it. Matter of fact, I think I'll go out and check mine again now. I'll clean my plugs and wipe out the New Day timer while I'm at it. Thanks for the reminder. ;)
Post by Norman Kling » Mon Aug 26, 2019 1:53 pm
The first time I changed a head gasket, 67 years ago, I didn't re-torque it, in fact I just tightened down the bolts in any order. As soon as the engine warmed up, I blew the gasket a few blocks from home. Learned that lesson and have not had one blow since.
Dan B
Last Name: Blaydon
Post by Dan B » Mon Aug 26, 2019 2:11 pm
How does one know when they blow a head gasket? And is any permanent damage caused?
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Mon Aug 26, 2019 2:21 pm
One of the cases that I saw was in the parking lot at the fairgrounds. A Model T was coming off the city street "just 'a 'smokin". When the driver came by me his exhaust smelled like anti-freeze. This is just one of the signs.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Mon Aug 26, 2019 4:20 pm
Usually it'll overheat or run poorly.
Unless you get a bunch of coolant in the oil for an extended period of time...no real damage.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Mon Aug 26, 2019 4:43 pm
Any blown gasket is a message to you to check the mating surfaces to ensure they are flat. In the case of head bolts, also time to verify the bolts don't bottom out in the block before getting fully tight. I check bolt/hole individually by laying the head on the block with no gasket and making sure they tighten up to the head rather than standing a bit proud. If the surfaces are flat, the bolts don't bottom out and are properly torqued (and retorqued) there shouldn't be any blown gaskets.
Post by TRDxB2 » Mon Aug 26, 2019 5:29 pm
Would have been nice to know what type of gaskets blew... too much to ask how they were prepped.
Kerry
Last Name: van Ekeren
Post by Kerry » Mon Aug 26, 2019 5:52 pm
A lot of variables on why a head gasket can blow, 7 are a lot in one tour! our nationals can have up to 140 T's for a weeks worth of driving and no head gasket problems.
Re-torque on the type of head, cast or aluminium, how it was done, surface condition etc, are usualy the things that contribute to a failure before you can blame the gasket it's self.
Doug Keppler
First Name: Douglas
Last Name: Keppler
Post by Doug Keppler » Mon Aug 26, 2019 8:16 pm
My engine is newly rebuilt and has maybe 25 miles on it, when I assembled it I carefully hand tightened All the bolts. While recently installing an air filter
with a bracket that bolts to one of the crankcase bolts I noticed the bolt wasnt very tight so I went around and checked every bolt on the engine and almost every one snugged up a little. So I think not only the head bolts need to be retorqued, check all the bolts, it might slow down some oil leaks also.
1924 Touring car
There's No Substitute for Proper Lubrication
Post by RajoRacer » Mon Aug 26, 2019 9:52 pm
Blue Loktite should be every Model T owners friend & in the tool kit !
