Hello:
Working on a 1927 Coupe and wondered if someone could tell besides the head bolts which bolts on the engine need to be nickel plated.
Thanks Steve
Nickel Plated Bolts
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Nickel Plated Bolts
The 2 bolts for the water outlet/fan bracket, and 2 bolts for the water inlet are dome shaped head nickle plated bolts like the head bolts.
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
I believe the manifold clamp bolts are nickel plated on the Improved Ford as well.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Walter T. Fishleigh's files in Acc. 94 at the Ford
Archives there is a memo dated July 26, 1926.
Nickel Plate used on:
Cylinder Head Cap Screws
Spark Plug caps and Thumb Nuts
Spark Plug Wire Terminals
Coil Box Terminal Bolts and Nuts
Water Connection Cap Screws
Manifold Cap Screws
Bright Zinc Plate used on:
Cut Out Cover
Moleskin Pyroxylin Used on:
Cylinder
Cylinder Head
Generator Bracket
Front Cover
Air Intake and Manifold
Manifold Cap Screws
Cut Out Cover
Cylinder
Cylinder Head
Generator Bracket
Front Cover
mytractor
Topic author - Posts: 23
- First Name: Steven
- Last Name: Smart
- * REQUIRED* Type and Year of Model Ts owned: 27 Coupe
Thanks all for the information.
