Vottage Regulator
Topic author - Posts: 1157
- Last Name: Govoni
Vottage Regulator
I just bought a real nice restored generator. Hank (the guy I bought it from) told me to make sure the voltage regulator was in good condition and to adjust the third brush. I ordered the wrench from Lang's as well as a Voltage regulator. My regulator was looking real rusty and bad. The one I ordered is on backorder. The say that the company that made them got bought out by another one and they are behind. This is the description of what I bought:
Without sacrifice of the original look you can now completely replace that troublesome generator cutout with the 6 Volt, Negative ground Model T regulator that has a Ford Script on the top as the originals. Enjoy the luxury of modern day electronics mounted in original style, generator cutout housing. Cruise with confidence knowing you have true field winding control (not just a diode) and protection from electrical system burn out which includes the battery and generator.
No lost "Show" points - exact replacement for generator cut out
Not just a diode but a complete electronic voltage regulator
Protects the generator and electrical system from burn out
No alterations to generator or car wiring - installs in minutes
No more dead generator or boiled away battery
Externally perfect in appearance - would have fooled Henry
Instructions included
My questions are has anyone run one of these? How do you like it?
- Last Name: van Ekeren
Re: Vottage Regulator
2 of my T's have generators and the only trouble I've had with them is the doide cut outs. one cost me a generator, a complete burn out and the other I caught in time when I saw the amp gauge go 100% neg. I'm sticking with the original type.
You are describing the "Fun Projects" voltage regulator. In the past they have been bullet proof, and if anything goes wrong witht the generator to destroy it, it will fail to ground (not open), thus saving your expensive generator. I have 4 T's, one of which is a starter T. I have one installed for about 5 years, and it is probably the best items you can ever put on a T in terms of it's electrical system.
If you haven't guessed by now, I highly recommend them.
- First Name: Douglas
- Last Name: Keppler
I agree with Scott, I have 1 on my car, it works great
1924 Touring car
There's No Substitute for Proper Lubrication
- Last Name: Saylor
The diode cut out is not a voltage regulator. The one with the regulator is a full solid state voltage regulator. Have never heard of one failing.
I opologize for any confusion, my bad habit of always calling them cut outs, dug them out of the junk tin and as can be seen they are not just the diode cut out.
- Last Name: Govoni
Thanks for all the info. I just got my 3rd brush wrench from Lang's. Now I just have to waite on the Voltage Regulator.
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
On back order, I've been waiting a year! Keep being told there on back order!
Quit holding my breath, still hoping!
Brian
Brian
Life is Good, be nice.
