21” Model A caps on Model T wire wheels
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Fri Sep 20, 2019 9:56 pm
Anyone ever successfully modify 1928-29 21” Model A hub caps to fit on Model T wire wheels?
Re: 21” Model A caps on Model T wire wheels
Post by Mark Gregush » Fri Sep 20, 2019 10:57 pm
Ya I know do it yourself, but why mess around, buy new ones.
Taford
First Name: Skip
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: '26 Coupe and '27 chassis
Board Member Since: 2010
Post by Taford » Sat Sep 21, 2019 2:26 pm
Hi Mark,
A few years back I posted a question relating to your question. I asked if anyone had a stock set of 1927 T wire wheels that used a Model A style hubcap. I received responses from four or five T owners that had similar wheels but they thought that they were just larger diameter with no hubcaps. My caps were AR style but the wire wheels were stock '27 T style. The typical '26/'27 hubcap would fall right through my wheel hubcap opening. All 5 of my wheels have a 2-3/4" opening for the hubcaps and I believe that a stock hubcap is around 2-1/2" in diameter. There was quite a discussion regarding my wheels, and some called me out, but when others came forward and had similar wheel openings it makes me wonder if these were late production wheels. Very hard to document. To answer your question however, yes in could be machined or bored out. I would not torch cut it however. Good luck.
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Sat Sep 21, 2019 2:35 pm
Thanks for the help.
I am NOT modifying the T wheels.
Just curious if the larger Model A cap could be made to fit the smaller opening in the T wheels.
Divcoone
Last Name: Giles
* REQUIRED* Type and Year of Model Ts owned: Speedster
Post by Divcoone » Sat Sep 21, 2019 8:18 pm
Model T wheels with a A cap and a T cap.
