Hard starting: sometimes the answer is simple
Post by Steve Jelf » Sat Sep 28, 2019 9:26 am
Even wearing an NH, Lizzie was making me work too much to get started. Wire brushing all the soot off the plugs improved starting considerably.
Mike Royster
First Name: Michael
Last Name: Royster
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout 1916 Runabout
Re: Hard starting: sometimes the answer is simple
Post by Mike Royster » Sat Sep 28, 2019 9:56 am
Had an old mechanic tell me one day "99% of all carburetor problems were electrical." I have found it often to be so!
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sat Sep 28, 2019 11:19 am
Steve, If you had so much soot that cleaning made a difference you probably need to run more lean. That could also account for your milage. Once you get up to operating temp on your long drives, turn back the carb adjusting needle a little.
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Sun Sep 29, 2019 12:46 am
Is the engine still a little stiff? How is it acting after the rebuild? Do you like the scat crank?
Joe Reid
First Name: Joe
Last Name: Reid
Post by Joe Reid » Sun Sep 29, 2019 12:50 am
As the engine “breaks in” do you have to make continuous adjustments? I keep having to adjust things on my 1920. It runs a little different. Do you have the standard clutch or is it the jackrabbit? Mine has a jackrabbit and it is really smooth.
George N Lake Ozark
First Name: George P
Last Name: Clipner
Post by George N Lake Ozark » Sun Sep 29, 2019 1:57 am
Years ago on this form was a debate on spark plug gap with high compression engines. The consensus was to narrow the gap to.025 from the normal setting of .030/.032.
Post by Steve Jelf » Sun Sep 29, 2019 10:56 am
The engine was as stiff as you might expect at first, but after driving over 2000 miles it turns as easily as ever. There's still some iron fuzz on the magnet when I change oil, but less each time The crank is fine. With so much attention to balancing rods, pistons, drums, etc., it's pretty smooth.
Stock Ford clutch. No problems.
I've been setting plug gap between .025" and .030", about .028". Maybe I'll narrow that to .025" and see if it makes any difference.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Sun Sep 29, 2019 11:08 am
Can anyone think of any reason at all why narrowing plug gaps from .03 to .025 should make things better in a HC engine - or any engine - if was starting OK at .03?
Post by Steve Jelf » Sun Sep 29, 2019 11:30 am
No, but if it wasn't starting perfectly maybe it would make a difference. If I understand this correctly, higher compression reduces the ability of plugs to make a spark. Maybe a slightly smaller gap would make for a better spark under the higher compression.
