Magnetic driveshaft
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Magnetic driveshaft
Post by Jim Eubanks » Tue Oct 01, 2019 4:55 pm
Just salvaged a driveshaft from an old rusty torque tube, had to heat the u joint and flail it a bunch to get it off. When I cleaned the shaft up, found that it had been magnetized. Anyone run into this before, guess at one time one of those junk yard magnets must have picked it up.
First Name: Henry
Last Name: Lee
Re: Magnetic driveshaft
Post by Henry K. Lee » Tue Oct 01, 2019 5:21 pm
That or dropped/strike towards the northern pole, Hard metals love the attraction.
Hank
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Tue Oct 01, 2019 11:10 pm
Jim, if you wish to demagnetize the shaft, you can use an armature growler. Switch it on, pull the shaft through and move it away and presto the shaft is no longer a magnet.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
Post by Jim Eubanks » Wed Oct 02, 2019 4:03 pm
Bob, I ran the shaft along my growler and presto, no more magnetism.
Thanks!!!!!
